Inverted Dome Tweeter replacement for a 626
0 Members and 1 Guest are viewing this topic. Read 4979 times.
tbrooke
« on: 22 Mar 2015, 08:38 pm »
I have an old pair of 626 monitors and I fried one of the tweeters. I think they are Focal T-120's but I am not sure. I have looked everywhere and can't find a replacement. Any suggestions: Anybody have a 626 they want to sell a tweeter our of?
 Of course if I could replace one great but if I have to substitute something else that would be fine. I really don't want to get into redoing the crossover if possible.
Here is a picture:
Stimpy
Re: Inverted Dome Tweeter replacement for a 626
« Reply #1 on: 22 Mar 2015, 10:02 pm »
There was a single Focal/VMPS T120 tweeter, recently on eBay.  I don't believe it sold.  Maybe email the seller, to see if it's still available?
http://www.ebay.com/itm/FOCAL-T120-TWEETER-FROM-VMPS-SPEAKER-/301527526693?nma=true&si=dsMULzvN1epPId9wyDdU4DFcR%252Fs%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Good Luck.
duck851
« Reply #2 on: 23 Mar 2015, 02:56 pm »
I've got one.  You can have it for $30.
spitfun
« Reply #3 on: 25 Mar 2015, 12:51 pm »
I don't think that is a T120K,I believe it may be a T90K. Measure the mounting plate to be sure,the T120K is larger.  Here is a picture of a T120K. Rich
spitfun
« Reply #4 on: 25 Mar 2015, 12:58 pm »
You may want to consider changing both to the Morel soft domes,it looks like yours may have have that type of tweeter originally by looking at the round mounting hole. I changed all of mine in my Supertower III,s and am satisfied with the sound. Rich
HAL
« Reply #5 on: 25 Mar 2015, 01:08 pm »
The Focal T120 has a titanium inverted dome.  They were used in VSR line of speakers.
That looks like a Kevlar dome as a comparison.  Those were also used in the original STIII's.
spitfun
« Reply #6 on: 25 Mar 2015, 01:34 pm »
When I mentioned the T120 I was referring to the T120k-yellow cone...
tbrooke
« Reply #7 on: 25 Mar 2015, 02:02 pm »
What model number is the morel soft dome and are they readily available?
spitfun
« Reply #8 on: 25 Mar 2015, 02:11 pm »
Below is a link to some replacement drivers someone put together on the forum-It looks like it may be the MDT-30 or it's replacement. Rich
http://www.audiocircle.com/index.php?topic=113729.0
tbrooke
« Reply #9 on: 25 Mar 2015, 04:20 pm »
Here is a link where this came up before:
http://www.audiocircle.com/index.php?topic=113638.0
I looked at Morel CAT-308 and MDT 29 on parts express but I am not sure they will work. the MDT-30 is no longer around
