0 Members and 1 Guest are viewing this topic. Read 9631 times.
Can Daphile turn FLAC into a compatible format for the Schiit Loki?
The other question is: how much DSD do you have? If little or none, don't worry right now about converting anything if you buy a decent little PCM DAC. Use your laptop, a good PCM (that maybe also does DSD...for later use) DAC and get the music flowing.
I'm a fan of DSD
I'm a fan of DSD and PCM to DSD upsampling
Loki does not "need a DAC to link with". It is a DAC. It also has a passthrough for any other analog output, but that is a marketing thing to make folks think it can integrate two DACs (for example). I'd never use it, I'd use a second preamp input...but then again anyone starting out would NOT want to deal with two DACs, two DAC drivers, two USB connections, etc. Argh! Just get one and have the player convert any incompatible format to the other. Better yet, get a DAC that will do both DSD and PCM.
