0 Members and 1 Guest are viewing this topic. Read 4804 times.
Congratulations!The 57 sounded terrific at Capital Audiofest--nice to see it out in the wild.Some questions: Is only the Pro version of the Bellina DAC board available as an option in the 57, or is the regular (one NOS converter) version also available?Is it correct that an upgrade to the batteries might allow the 57 to have a higher power output in the future? (Can't recall where I picked up that idea)How would the Bellina DAC module decide which input to use? On the stand-alone Bellina there's a selector switch on the back, but on the 57 rear I don't see one in the photo.Thanks!
I'm impressed by the modular design of the Sig 57, and I have a question. Would it be possible to get the basic version of the Sig 57 and then upgrade it later with DAC and phono stages? Or do all of those options have to be ordered at the start?
Frequency Response: 5 Hz to 28 KHzImpedance: 46 ohms nominal (non-reactive)Sensitivity: 85 dBDistortion: Less than 1%; Less than 0.2% through ears most sensitive range
Typical output impedance (measured at 1 amp, 60 Hz): 0.6 Ohms to 2.7 Ohms, depending on tube complement.Sensitivity at 30 W output: 8 ohms: 0.4 V RMS to 0.75 V RMS, depending on tube complement and load impedance.Input impedance: 50 kOhm
57 watts RMS per channel into 8-ohms115 watts RMS per channel into 4-ohms
Hi Vinnie:Is there any sonic difference/advantage going form Sig 16 to Sig 57 other than more power either with and without the dual tube input? Been eye-ing the 16 for my 100db/watt speakers... have the Bellina in walnut and might want the amp to match down the road.
Vinnie, you will be present at the Montreal Audio Show?http://www.salonsonimage.com/EN/index.html
