0 Members and 1 Guest are viewing this topic. Read 15782 times.
Good point. And as I always seem to be mucking with gear, those ongoing visits gets pricey. Maybe getting the installer kit used and going DIY makes more sense. But I can just see myself going crazy and blind constantly fiddling with it. I guess sometimes you have to say : good enough is good enough. Interestingly a friend thinks he can improve the results with his audessy xt getting a better aftermarket mike. That should prove interesting.
If you do the Audyssey MultEQ XT Pro calibration, you use the mic that comes with the pro kit; only for units that are Audyssey MultEQ XT Pro Ready. If you do the Audyssey MultEQ XT, you use the Audyssey pyramid type that comes with your unit. ...Internal calibration of your particular unit.{This last one includes all Audyssey flavors; 2EQ, MultEQ, MultEQ XT, and MultEQ XT32.}Should be clear now.
After having flayed about with various room correction products and programs (including XT32 but not the Pro), I've become convinced that PEQ is limited only to smoothing peaks and dips....not fixing them. Your question just reminds me that with the PRO you'll be paying a lot for a limited improvement on the fine tweaking ability of the EQ filters. A program like Audyssey can only make 6 dB (or so) changes without it smearing your equipment's output...especially on the boosting of dips. So for certain, you are limited by a large extent to the sonic signature of your room. If it's awful, the Pro won't help. If it's not awful, the XT32 should do just fine.But, for me anyway, room treatments are a far more valuable investment in controlling room acoustics. Good luck with your project.
Yes, i understand which mic is used with which application. What I'm saying is that I don't think that either the pro kit mic, nor even the pyramid mics, are calibrated for your specific receiver / processor. If so there would be mention of it in the very thorough manual saying you must use the pyramid mic that came with your unit - or get another calibrated for your unit if you lose it. This not being the case I'm assuming the pyramid mics are universally usable (as well as the pro kit mic).
Well they also claim with audyssey that it works not just in the frequency but also time domain....Hard to know if 6db is enough, but it seems like plenty to me! Fortunately aside from a node somewhere in the 30-40hz range, it doesn't seem like my room has big acoustical issues. Ultimately acoustical treatments do seem to make the most sense though it's hard for the layperson to know where to start. I guess that's the appeal of automated room EQ, however limited in practice the results may be.
Whatever, but what I just said to you is from Chris Kyriakakis, the Audyssey man himself. You can contact him from his various blogs. Just google Audyssey FAQ. => http://www.audyssey.com/audio-technology/faq <<<>>> {Just go to MULTEQ QUESTIONS section.}And me, I'm nobody, just a guy that has been into Audyssey extensively since the very beginning (2004). ...And much more.
