0 Members and 1 Guest are viewing this topic. Read 2952 times.
For those with an OXO, this is a walk in the park, and you follow Dave's diagram exactly.
Housteau,I'm a bit confused by the block diagram. It looks like tweeter has a high pass function provided by the analog crossover, but the mid does not get a low pass function since it is split directly from the mid/tweeter output of the amplified DCX out. Would it make more sense to just use the "mid" output of the high-level analog crossover and connect that to the mid? Just wondering.
One of the benefits of using the DCX is the removing of the midrange Neo panels from the analog xover.
Yes. But the response of the midrange panel now fully overlaps the tweeter response in your configuration for better or for worse. Is this how Brian Cheney designed the passive crossover for the tweeter/midrange for this speaker?
In his article Brian refers to a "Modded Behringer DCX2496". Questions that come to mind are:- What are the modifications?- Can the same benefits be realized with a "stock' unit?- Is a DIY implementation of the mods possible?- If not, how would one go about getting a modified one?
A good benefit of using an OXO is that you will have a rotary pot to help adjust the tweeter level relative to the other drivers.
Does that info exist somewhere?
