BDP-2 Digital Player
0 Members and 1 Guest are viewing this topic. Read 553241 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-2 Digital Player
« Reply #120 on: 18 Nov 2012, 05:12 pm »
HI James,
On the Mac both XLD and MAX support uncompressed FLAC encoding. They're getting better with each update, especially in finding correct Album Art, and convenience.
Marius
Thanks.
james
SGK
« Reply #121 on: 18 Nov 2012, 05:20 pm »
HI James,
Marius
I am using XLD to generate ALAC.
Back to my question about subfolders etc?
SGK
« Reply #122 on: 18 Nov 2012, 05:24 pm »
Apple lossless will work OK but the others are just faster
I find this a puzzling statement.  How is the BDP doing its indexing of the drive?
« Reply #123 on: 18 Nov 2012, 05:34 pm »
Hi SGK
I am not sure it is just that I find the load times when you load a new drive works faster.  I will ask Chris the tech details.
james
SGK
« Reply #124 on: 18 Nov 2012, 05:38 pm »
Thanks as it is linked to my other question about indexing via USB2 versus eSata.  When I raised the notion of USB 2  attached drives with my tech department at the office the first thing they said was that it would likely be extremely slow to scan and browse an attached drive.  This is part of the reason why I am thinking about the 2 version.
SGK
« Reply #125 on: 18 Nov 2012, 05:47 pm »
James, how do you arrange the files on the drive?
iTunes creates a folder for each artist and then, within that, for each album.  What's recommended with the BDP?
« Reply #126 on: 18 Nov 2012, 05:52 pm »
I just use by "Artist".
james
« Reply #127 on: 18 Nov 2012, 05:53 pm »
Hi James, did you try using uncompressed FLAC?
Also, not sure what current and future BDP owner are using for handling there library? Foobar, Jriver, MediaMonkey ? iTunes is not my cup of tee.
Hi
Thanks - I downloaded DBPoweramp Converter and will give it a try.
james
SGK
« Reply #128 on: 18 Nov 2012, 06:05 pm »
james
So no sub-folder for each album? I'm presuming you browse artwork or simply search by album or artist is MAX (if I recall the name of the software correctly).
« Reply #129 on: 18 Nov 2012, 06:19 pm »
Correct - I use MAX 2 and MPAD and MPOD most of the time on my IPAD and GNOME on my PC laptop.
Use Amarra, Pure Music, Audirvana and Bit Perfect on my MAC Laptop (iTunes).
james
SGK
« Reply #130 on: 18 Nov 2012, 06:27 pm »
Thanks. I will be using an old iPad as a controller. I had a look at going down the Mac Mini route with Audirvana but have instead decided to use the BDP. (I have the simplest of Harmon Kardon Soundsticks and base thingy attached to my desktop - not for serious listening.)
rompolompo
« Reply #131 on: 19 Nov 2012, 02:54 am »
james
There are couple of things to consider.
1. The more sub folders you have, the more time (slowest) the scanning and indexing process will take.
2. MPD does NOT "arrange" the structure of files. It is up to the application you use to display them according to your preferences.
I use the following:
Artist - Album
For example:
The Doors - Morrison Hotel
The Doors - Strange Days
The Doors - The Soft Parade
Songs are arranged in the following way:
01 - Tell All the People.flac
02 - Touch Me.flac
03 - Shaman's Blues.falc
If you need to copy an album, you just copy the relevant folder.
rompolompo
« Reply #132 on: 19 Nov 2012, 02:57 am »
It is faster o read and calculate the metadata from FLAC files than ALAC files. Unless you work for Apple or own a share, there is no real reason to use ALAC.
jjc1
« Reply #133 on: 19 Nov 2012, 08:15 pm »
   James,what flash drives do you recommend? I'm thinking of getting some 64 GB drives for the BDP.
« Reply #134 on: 19 Nov 2012, 08:19 pm »
This may sound insane but try the Cruzer Thumbdrive - they sound excellent!!!!
james
jjc1
« Reply #135 on: 19 Nov 2012, 08:38 pm »
    Thanks James. Will give them a try.
unincognito
    • bryston.com
« Reply #136 on: 20 Nov 2012, 03:24 am »
Personally I remove the plastic casing from my USB drives and get my mason buddy to re-encase the USB thumb dive made of solid state memory in concrete to prevent vibration.  They sound amazing, even 64 bit mp3's sound outstanding!!!!!!!!!!!!!
Chris
loopyground
« Reply #137 on: 20 Nov 2012, 04:21 am »
Chris
Would that void the warranty?   :icon_lol:
SHV
« Reply #138 on: 20 Nov 2012, 05:03 am »
Chris
I didn't find that improved the sound that much...try dense concrete with three spikes sitting on an platform of Dalbergia melanoxylon wood.
srb
« Reply #139 on: 20 Nov 2012, 05:15 am »
Forget all of this nonsense about anti-vibration thumb drive encasements and let me know where can I get me some of those 64-bit MP3s!
