0 Members and 2 Guests are viewing this topic. Read 553198 times.
That is good news James Does the Euro version ship next week too?
Starting to reRIP my entire CD collection to ALAC ahead of picking a BDP up. Any tips re organising files etc?
Why rerip it and not just convert them? It's much quicker to convert.
HiI would recommend Wave or Flac or if you want to stay with MAC then AIFF. James
AIFF is grossly inefficient. I guess I can convert the ALAC folder to FLAC when done. I thought you had ALAC up and running properly. Time to see the light...What about subfolders etc or do you guys just drop all the individual files into one big folder?
Apple lossless will work OK but the others are just faster and Wave sounds best.james
There are many reports that they sound the same.
Hi jwYes I know the discussion rages on - but with the tests I have run on my setups I just prefer Wave. james
So it's all subjective?
I guess so - Each person chooses their system based on what they feel provides the best performance and the emotional connection they are after.james
Well, of course they do but I was just curious to know how you came to the conclusion that one was better then the other. That's it.
Oh sorry - just listening to all the different versions in my setups the WAVE seems to provide the best overall response for me.james
Hi James, did you try using uncompressed FLAC?Also, not sure what current and future BDP owner are using for handling there library? Foobar, Jriver, MediaMonkey ? iTunes is not my cup of tee.
I have not - what converter program allows for uncompressed Flac - I have MMonkey and JRiverjames
DbPoweramp does, and sounds best to me.Cheers
