0 Members and 1 Guest are viewing this topic. Read 84475 times.
I have spied that same 211 - think it is a Topaz?
8 ohms is not the loudspeakers impedance ... it is the nominal impedance,and tells you VERY little.dave
i heard a couple of pairs of 211 SET monos at the Capitol Audiofest.i believe one pair were Audio Note
DougS - I have the Audio Mirror 20 watt version. Very good bargain indeed. And look what this guy did to his:http://www.troelsgravesen.dk/AudioMirror.htmSince I don't get out much, tell me how these Audio Mirror products compare to the best. I really have no idea.I've been in this town for almost 12 years and there still has never been one High End audio show. Can you believe it?
I mentioned "benign 8 ohms impedance" which I meant to be a flat 8 ohms, or at least relatively flat.
Hi.Yea, Audio Note of Japan builds & sells the MOST expensive amps on this planet. I am talking about the 211 SET monoblock pair - "Ongaku".
What about the $350k Wavac?dave
Which Wavac?
http://www.stereophile.com/tubepoweramps/704wavac/index.htmldave
