Beautiful, hand built stereo, EL84 tube amplifier with all handwired, point to point circuitry on a garolite board, using the RH EL84 SE design. This amplifier is a very popular design and produces fantastic sound. This amplifier layout has been carefully redesigned using less wire and a combination of Vintage, and high quality components that make the amp sound even better. These components consist of choke-input power supply, transformers, IEC plug, and gold-plated RCA and speaker Jacks. This amplifier has built in volume control and does
not need a preamp. You can connect the audio out from an iPod, CD, DVD, MP3, VCR, TV, XM or SIRUS to the input connection. Amplifier was designed utilizes three tubes, one 6N1P(Input) can be substituted with 6922,6FQ7,6EV7,6GU7, 6CG7 or 6DJ8 and two 6P15P (Output) can be substituted with El84, 6BQ5 or SV83. This amplifier features normal
input, volume control, power switch, power indicator, right/left speaker terminals (8 Ohms) and circuit protection. You will be amazed at the bass sound of such a small amplifier.
Amplifier will be fully insured at no extra charge. Amp will be bubble wrapped, double boxed and guarded with packing peanuts. Will ship with FedEx or UPS. Usually ships the first business day after payment is made. I will email buyer tracking information.
Specifications:
* Input connector - Two Gold RCA input jacks (Right & Left).
* Built-in volume control (does not need a preamp). you can connect the audio out from an iPod, CD, DVD, MP3, VCR, TV, XM or SIRUS to the input connection.
* Tubes 1-6N1P(Pre-amp) and 2-6P15P(Output).
* Normal input(R,L), Volume control, Power switch, IEC plug, Standby switch, Power indicator, Speaker terminals(8 Ohms) and Circuit protection.
* Circuit Type: Single-Ended Class A
* Power Output: 6 watts
Asking $595
Custom Made Amplifiers by: WaamampS For more info:
www.waamamps.com Any questions please email me at
waamamps@att.net
