Schumann Resonance Generator SW1
0 Members and 2 Guests are viewing this topic. Read 30521 times.
ted_b
Re: Schumann Resonance Generator SW1
« Reply #20 on: 30 Apr 2012, 11:29 pm »
Photon46, what are your room dimensions?  The off-brand SW1 seems underpowered compared to the RR-77, and as I posted, underpowered boxes will show their limitations quickly.
golfugh
  • Dead Can Dance - Into the Labyrinth
« Reply #21 on: 30 Apr 2012, 11:44 pm »
Ted
Dropping you a PM
Mark
santacore
« Reply #22 on: 30 Apr 2012, 11:51 pm »
I recently bought a Earthsafe whole house generator and didn't notice much of a change. To be fair, it was purchased second hand, and has a variable frequency output, so I can't be sure exactly where the dial should be set. Does any other member have a Earthsafe unit? If so, could you take a pic of where your frequency knob is set at?
If I can't get this unit to improve, perhaps I'll try the RR-77 instead.
Photon46
« Reply #23 on: 1 May 2012, 12:21 am »
My room's about 14.5' x 19' with 11' ceilings. A bit over 3k. cubic feet.
roscoeiii
« Reply #24 on: 1 May 2012, 12:34 am »
I think a 6moons article discusses these
ted_b
« Reply #25 on: 1 May 2012, 02:55 am »
I would be very surprised if an SW1 covered that space.
Charles Xavier
« Reply #26 on: 1 May 2012, 09:51 am »
I think you can use more than one unit.I know Satfrat has 2 RR 77. But that might be for a better effect
ted_b
« Reply #27 on: 1 May 2012, 01:57 pm »
I 100% disagree on using more than one.  They generate a pulse; how can two units generate the same timed pulse?
Mike B.
« Reply #28 on: 1 May 2012, 03:32 pm »
I recently purchased a unit from Taiwan. My initial feeling was one of being a bit high. It was definitely having a effect on me. And the music filled the room. Has anyone else experienced this feeling?
Photon46
« Reply #29 on: 1 May 2012, 04:37 pm »
Interesting observation. In retrospect, I would say I felt slightly disoriented and a bit "high" the first time I was exposed to the SW-1.  That effect passed after the first night however. I'll have to try leaving it off for a period of time and see if my nervous system has to re-acclimate to the Schumann field.
jtwrace
    • TIPP YouTube Channel
« Reply #30 on: 1 May 2012, 04:39 pm »
Never been high before so I can't tell you what I felt.
ted_b
« Reply #31 on: 1 May 2012, 04:48 pm »
Well Jason, now your credibility about all your favorite stuff (ncore amps, etc) just went to zero!!     :)  (just kidding)
Photon46
« Reply #32 on: 1 May 2012, 08:33 pm »
jtwrace
« Reply #33 on: 1 May 2012, 10:12 pm »
That is correct!  Not even a sip of alcohol.  Nope, no family members are alcoholics.
I simply have never had the urge or curiosity.
roscoeiii
« Reply #34 on: 1 May 2012, 10:15 pm »
Fast cars and good sound are sufficient huh?
jtwrace
« Reply #35 on: 1 May 2012, 10:21 pm »
No, I think happiness is key.  Of course both of those things contribute to my happiness but it starts waaaay before them IMO.
roscoeiii
« Reply #36 on: 1 May 2012, 10:30 pm »
Well put friend. Well put.
jhm731
« Reply #37 on: 1 May 2012, 11:12 pm »
Try a cup of Kava.
jtwrace
« Reply #38 on: 1 May 2012, 11:56 pm »
Try a cup of Kava.
I looked it up here //en.wikipedia.org/wiki/Kava
I have no interest in altering my state of mind in that way though...   :scratch:
« Reply #39 on: 2 May 2012, 12:09 am »
In the 1960s my farher warning me about tabacco and alcohol, and I always hate these stuff.
So I must thank my father for these words. Thanks Dad.
