New MKII Upgrade Power Supplies!
0 Members and 2 Guests are viewing this topic. Read 16968 times.
jtwrace
    • TIPP YouTube Channel
Re: New MKII Upgrade Power Supplies!
« Reply #20 on: 30 Apr 2012, 04:32 pm »
What are is the max voltage?    Max load?
CIAudio
« Reply #21 on: 30 Apr 2012, 05:49 pm »
How about the Auraliti PK 100? It takes 12 vdc.
Do you know the connector type and maximum current draw?
jtwrace
« Reply #22 on: 30 Apr 2012, 06:29 pm »
4 pin XLR and say 6 amps max.
Paul_Bui
  • Rode NTK and S-1 microphones
« Reply #23 on: 30 Apr 2012, 06:42 pm »
SB Touch, please!
rw@cn
« Reply #24 on: 30 Apr 2012, 07:29 pm »
I'll contact Auraliti. It is not an XLR. I think there is a bit of confusion here. I'll PM you when I get the information.
CIAudio
« Reply #25 on: 30 Apr 2012, 08:15 pm »
SB Touch, please!
Our first available model will be VDC-5 MKII and will come with an output cable for the Touch. This and the VDC-9 MKII will be available in a few weeks. The 9V model can be used with SB Duet, Wadia 170 & 171 iTransport.
radarnyc
« Reply #26 on: 12 May 2012, 06:32 pm »
How many devices are you proposing to power from a single power supply?
As with others, I vote for a SB Touch. I'd also like to see an option for vortexbox appliance from Small Green Computer - http://shop.smallgreencomputer.com/
CIAudio
« Reply #27 on: 14 May 2012, 03:31 am »
Our supplies are designed to power a single device. Powering multiple devices can introduce ground loops and other noise problems as well as reduced performance as less current is available for each device.
Do you know the voltage/current requirements, and the type/size of connector used?
I don't see any specifications listed on their website.
H2K
« Reply #28 on: 14 May 2012, 04:48 am »
How about something that is better than this
http://www.hd-plex.com/psu.150w.html
CIAudio
« Reply #29 on: 14 May 2012, 05:07 am »
Sorry, we don't make switched mode computer supplies.
CIAudio
« Reply #30 on: 26 May 2012, 07:00 pm »
1st photos of VDC5-MKII (matching Upgrade Supply for Transient MKII and Squeezebox Touch).
Sorry for the poor pic quality, taken with my iPhone on my bench  :)
tonyptony
« Reply #31 on: 26 May 2012, 10:52 pm »
Looks nice. Any discussion on price?
CIAudio
« Reply #32 on: 26 May 2012, 11:43 pm »
All DC models will be $329
jtwrace
« Reply #33 on: 27 May 2012, 03:23 am »
Any update on the max voltage and amp rating on the unit?
CIAudio
« Reply #34 on: 27 May 2012, 04:31 am »
I assume you're talking about the maximum input voltage for the Transient MKII?
I probably won't know this for a couple of weeks... right now we're getting things ready for the Newport show next weekend.
After the show we'll do some long term testing. I'll have to check temperatures & performance of the internal regulators at higher voltages. The internal circuits run at 3.3V, so 5-6V is ideal. My guess is 9V will probably be the maximum (maybe less).
Current draw is <500mA, but I always prefer a supply that is capable of at least double the maximum required (VDC-5 MKII is over 4X).
fourxmotion
« Reply #35 on: 6 Apr 2013, 06:10 am »
Dusty made me a custom VDC-9 MKII for my Simaudio 180 MiND.  I will be getting it in a few days.
CIAudio
« Reply #36 on: 6 Apr 2013, 03:04 pm »
Yes, this is a 12V/1.2A version (VDC-12 MKII).
HumanMedia
« Reply #37 on: 25 Apr 2013, 02:53 pm »
When will a 12VDC supply be available to buy? Cost?
CIAudio
« Reply #38 on: 25 Apr 2013, 03:42 pm »
We can provide them now... just haven't got them on the website yet.
VDC-12 MKII cost is the same as VDC-5 & VDC-9 MKII ($329), and comes with 2.5mm DC cable.
Depending on the product you wish to power with it, you may need a custom output cable.
jtwrace
« Reply #39 on: 25 Apr 2013, 04:00 pm »
How many amps?
