The GIK Scopus Tuned Trap is HERE!
0 Members and 1 Guest are viewing this topic. Read 18510 times.
bpape
    • Sensible Sound Solutions
Re: The GIK Scopus Tuned Trap is HERE!
« Reply #40 on: 23 May 2012, 04:21 pm »
I would agree that for general ringing and dialog issues, you may be better off with a more broadband solution.  Or, you could do multiple Scopus tunings.  It's hard to get them up into the dialog range though.  If you'd like to start a new thread with some of your pictures, dimensions, maybe a measurement, that would be a good thing and I'll be happy to take a look.
Bryan
Vaughan
« Reply #41 on: 24 May 2012, 09:03 am »
Thanks Bryan. Unfortunately I'm not able to take any measurements as yet, but hopefully soon. Perhaps I should wait until then otherwise you won't have the whole picture. I could send you pictures of the room, but I'm not sure if that's enough.
bpape
« Reply #42 on: 24 May 2012, 01:12 pm »
Go ahead and email me whatever you have (pics, sketches, dimensions, etc.) and I'll be happy to take a look.
bryan dot p at gikacoustics dot com
Bryan
Vaughan
« Reply #43 on: 25 May 2012, 08:24 am »
Thanks Bryan, I really appreciate your help. I'll send some pictures your way.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #44 on: 19 Dec 2014, 05:14 pm »
Hmm... Why are these so heavy? Are they made out of wood or plastic or what?
Glenn Kuras
« Reply #45 on: 19 Dec 2014, 05:19 pm »
Thanks John.. Keep us posted if you have any questions.
TRADERXFAN
    • GALLERY
« Reply #46 on: 23 Dec 2014, 07:32 pm »
inquiring minds would like to know!
 LOL
Glenn Kuras
« Reply #47 on: 23 Dec 2014, 07:46 pm »
 LOL
The framing is solid 3/4" wood. The membrane on the front is 2 pounds per square foot and it has ridged fiberglass inside.  When making a tuned trap it has to be pretty solid for it to work. You only want the front membrane to move, if at all possible.  There really is no way to make something light weight. The nice part though is it takes up a lot less foot print vs broadband.
