What turntables are easy to set up for a novice?
0 Members and 1 Guest are viewing this topic. Read 7443 times.
Minn Mark
Re: What turntables are easy to set up for a novice?
« Reply #20 on: 28 Oct 2011, 06:01 pm »
Appreciate your comments, Wayner. I do remember those posts.
My suggestion (recommendation ?)  is based on my N=1 experience with th Debut III I bought from ND.  While it is not comparable to my more expensive TT's (I even like my old Technics SL-D3 better), for me it did "work right out of the box". The aliignment I checked with a geo-disc (was OK), and I use a digital scale to set tracking force. I use my Debut III mainly for listening to 78s (I had to order and install an alternate pulley allowing 33/78, and also purchase the 78 stylus for the supplied Ortofon cart).  For my use it works OK.  Happy listening !
M
jjc1
« Reply #21 on: 28 Oct 2011, 06:42 pm »
If you don't want to make the leap because of 'setup anxiety', you can have it done at a shop.
Almost every shop that I know of that sells TT's, new or used will configure it for you. Any shop that is selling TT's is usually a service oriented shop, as opposed to a price oriented shop. They will want to make sure your TT is set up correctly in order to make a customer.
When you spend a $1000 - 3000 on a TT, you are already putting yourself in the enthusiast category, whether you get into tweaking the TT yourself or not.
As already stated, you can get a Clearaudio Concept pre setup for abut $1500 or a Clearaudio Performance for about $2700, both are almost plug and play
  The Concept is set up in Germany and shipped that way The Performance needs setup. My dealer did it when I purchase mine. But any decent dealer should offer to set up a TT when purchased through them.
doug s.
  • makin' music
« Reply #22 on: 29 Oct 2011, 12:03 am »
There is a learning curve but don't be intimidated.  If you are like most husbands, you are seemingly running to Home Depot every weekend to get something or another to do house repairs.  The first time you sweat a pipe joint you take like hours using up  10 times the solder as most land on the floor.   Once you have done it you can say it really wasn't much.  Same thing applies to TT set up.  Once you have done it, it's not really that complicated.  Do you have to be patient?  Yes, because it's often small adjustments in tight spaces.  But the steps are not hard to conceptualize or understand.
Get a compatible table/arm/cartridge. This is where you need to do the most research.
Assuming the arm is installed, install the cart.  There are various protractors and templates to help you.
Attach the color coded leads.  Use a forceps or an alligator clip to connect.
Use a scale (manual balance type or digital meter) to set to the middle of recommended tracking force.
Use a test Vinyl to check/adjust phase, balance, azimuth and tracking force.
Fiddle with your arm height to get the right rake angle (Vertical Tracking Angle is the same thing more or less) to get the sound you want -- remember high/high, low/low.  Higher arm placement will accentuate treble and lower placement will accentuate bass.
Establish a good clean and demag routine and spin the vinyl.
Drop the needle.
Sit back and enjoy.
There has to be someone in the Atlanta area who would be willing to come over to show you the ropes.  Most vinyl enthusiasts I know will be glad to help other people get started.
BTW,  It's easier to do these adjustments on more expensive arms.  The easiest arm I ever had to install and use is Graham Phantom II.  I have been fiddling with my set up recently because I got a new cart and everything can be adjusted with a turn of a knob.  I can change the VTA while I am playing the music.  How cool is that!
If I have 3k, I would look for a killer deal on a TT/arm/pickup package deal.  For example, this Table/arm/accessory is a great deal only because it's a package deal.  Don't be afraid to get a Beamer just because you haven't driven one before if a great deal lands in your lap. :wink:
+1 on rim's suggestion - both on how to deal w/set-up, and on getting a used killer all-in-one rig at a killer price.
doug s.
SET Man
« Reply #23 on: 29 Oct 2011, 03:33 am »
Hey!
   I wish I had that kind of budget when I first started out on vinyl. :D
   Anyway, there are some all in one plug and play TT out there. But if you are serious and will have vinyl as part of your music play back for a long term than I would suggest leaning the process of setting up cart.
   With your budget just get the TT you want, set a side some money for set up tool like scale, protractor, brush and etc. Than get inexpensive cart like $100 or less and learn how to set it up on your TT. Once you get it right play with it a bit, get to know your tonearm and TT than get the better cart that you like.
   But if you don't want to tinker with setting, maybe find an audiophile friend that can help you with it.
   Anyway, good luck.
Take care
Buddy :thumb:
AllynW
« Reply #24 on: 29 Oct 2011, 05:37 pm »
No TT advise but I will add,  a really good phono pre-amp is just as important as table and cartridge.
When I got back into vinyl, I went thru four TT's w/cart. & phono pre-amps learning what worked for me. For me the phono pre-amp has turned out to be 50 % of the game.
Good luck.
SteveFord
« Reply #25 on: 29 Oct 2011, 08:02 pm »
How about the Well Tempered Adamdeus?  That looks pretty straight forward.
midfi
  • nisi credideritis, non intelligetis
« Reply #26 on: 2 Nov 2011, 11:29 pm »
Sorry Mark, but that is one of the 5 tables I purchased and reviewed last winter, if you will remember, and my conclusion was that is was a POS.
I thought it would be a better table until I unboxed it and started to work it. The stylus was not in any known alignment, the dust cover hinges look like they were made to work about 10 times, then break, and don't get me started on the anti-skate mechanism (hanging fishing tackle).
Everything about this table was on the cheap, but then it was inexpensive. I just couldn't recommend it to anyone. Much better to spend some more money (even on used stuff), then to deal with this TT, IMHO.
Wayner  8)
agreed... I bought one NIB a few years ago. Set it up, played with it for a week, put it back in the box and put it on Craigslist.  What a phenomenal waste of time and money.  bought another DUAL off of E-Pray and haven't looked back.
doug s.
  • makin' music
« Reply #27 on: 3 Nov 2011, 12:00 am »
wow - a dual is better?  that project must really suck!  i had a dual 1219, (bought new, at the ripe age of 13, when i didn't know any better - coulda had an empire...) it was easily bested by a $100 plastic pioneer, which i picked up after college.  lower noise floor, better pitch control, more reliable.  one of my happiest audio experiences was finally literally heaving the pos 1219 into a dumpster.   :green:
ymmv,
doug s.
Gopher
« Reply #28 on: 3 Nov 2011, 12:27 am »
I believe he just sold that, but my experience with Well Tempered is that setup was...  exhausting!  Not a novice deck (owned a classic and reference).
That said, I just replaced my Well Tempered Reference with a Kuzma Stogi S/Stabi S and it really is an easy table to setup that sounds as good or better then my Ref did.  I don't know what they're selling for new these days, but I picked mine up used at a bargain price.  Drop Rollo a PM, I think he's carrying 'em now.
SteveFord
« Reply #29 on: 3 Nov 2011, 01:01 am »
No argument about the older WT's driving you slowly insane at times!
TONEPUB
« Reply #30 on: 3 Nov 2011, 02:15 am »
Grab a Rega RP3 with their best MM cart.  you'll have it up and running in five minutes...
About $1200.
doug s.
  • makin' music
« Reply #31 on: 3 Nov 2011, 02:33 am »
About $1200.
i cannot imagine a wintage empire being much harder to set up.  ya, it might take you an extra 15 minutes to mount the cartridge of your choice.  but the extra cash ($400-$800, depending on how patient you are getting a good deal), would certainly be worth it, imo.  of course, the better sonics wouldn't hurt, either.   8)
ymmv,
doug s.
midfi
« Reply #32 on: 3 Nov 2011, 04:43 pm »
ymmv,
doug s.
Yup, my mileage varies in the other direction of yours I guess.  The 1219 is one of the most sought after with great sound to boot. Yours must have been out of whack or not set up properly or something but it is what it is. If you come across another one don't dump it, you can get $350+ easy on E-Bay for 1219's (701/721/1229's too).
doug s.
  • makin' music
« Reply #33 on: 3 Nov 2011, 05:21 pm »
i dumped mine before ebay was born.  :lol:   if i had known, i woulda kept it for resale.  it always gave me operational problems once it reached about 2 years old - i was constantly fiddling w/its myriad internal innards.  and its wow was wisible on its built-in strobe, and easily audible, ewen when brand-new.  at age 13, i simply figured that was as good as it was supposed to be - today, it would get returned in an instant.  ya, mebbe it was a lemon.  but my parents 1215 was pretty-much the same...
doug s.
rollo
  • Rollo Audio Consulting -
« Reply #34 on: 3 Nov 2011, 07:11 pm »
About $1200.
  Excellent advice. VG sound to boot.
charles
SMA
