Now stacked Mini Maggies, that gives me some more ideas.
What interests me in the Mini Maggies is achieving the best sound qualities that I might achieve with Stax headphones and Woo Audio headamp without being tethered ...
The current advertisement for the Mini Maggies is put the 3.7 on your desk, so IMO Magnepan believes that for sonics the Mini rival the 3.7s ...
What interests me in the Mini Maggies is achieving the best sound qualities that I might achieve with Stax headphones and Woo Audio headamp without being tethered and as a secondary audiophile speaker reference system.
As Wendell says, there are advantages to a full length line source. Also, if a line source is short compared to a wavelength, it will start acting like an omni. Not a good thing, since the radiation pattern will change with frequency.Have you looked at Satie's Tympani mod on the Planar Asylum? He combines the Maggie ribbon with a line source made with the BG Neo-8's, which are quasi ribbon push-pull planars. I suspect you'd get much of what you're looking for with a combination like that.
It's hard to imagine two Mini Maggie panels stacked above each other would be anything but a line source. I would guess that the bottom of lower panel to the tip of the top panel would be about 30 inches. What constitutes a full length line source when you are seated? Can that be described in the length of the Maggie ribbon projected and flared out to a larger length at your seated position?I would love to hear Satie's system, I'm sure it sounds fantastic. If I only had the DIY skills and craftsmanship. Perhaps I do need to hear Satie's system to get me motivated.
I believe some people are even tri-amping their larger Maggies.
"In a very real sense, the 20.1 or a 3.7 are smaller than an MMG. If Magnepan sold only the portion of the 3.7 or 20.1 that operated from about 200 Hz and up, the question of speaker size/room size would never come up. An ideal ribbon line source driver is very narrow and would go from floor to ceiling. Most of the area of a Magneplanar is needed for bass reproduction."The above answer begs the question, what are the dimensions of the midrange and tweeter drivers in Maggies? It would also seem that if the ideal ribbon line source driver should go from floor to ceiling, none of the Maggie speakers would be deemed ideal (unless you have a very low ceiling).
