Why does my squeezebox make a jarring noise after tracks?
0 Members and 1 Guest are viewing this topic. Read 1038 times.
Gopher
This is something new--it didn't used to do this, but my Bolder Modded SB w/ Soundcheck software mods makes a brief, piercing noise at the conclusion of a track.  it only lasts a second, but is very jarring and I'd like it to stop.
FWIW, its feeding a Bolder'ed EE DAC.
Is there a setting or something I can toggle?
bprice2
Re: Why does my squeezebox make a jarring noise after tracks?
« Reply #1 on: 24 Oct 2011, 02:36 pm »
I think it's the Soundcheck mods.  Mine does it too, as well as dropouts when using digital outs.  SC TB 3.0 will be released today or tomorrow.
mjock3
« Reply #2 on: 25 Oct 2011, 05:06 pm »
If you made the Soundcheck mods, it is the buffer setting. If you want to get rid of the noise raise the buffer setting until noise stops.
