0 Members and 1 Guest are viewing this topic. Read 5175 times.
Ok quit being so damn lovably nice already.
As mentioned earlier, I'd like the Dodd tube buffer upgrade if possible? RegardsD
This post at Jason then. I see in the 'Tube Buffer Necessary' thread that you're "running in some Clarity MR caps right now without a buffer and it sounds fantastic. If you do the buffer and caps I think you'll be amazed." ----(Hey. Someone tell me how to do quotes correctly?)----I don't really know what's wrong with my amp so I guess the smart move is to send it back in case things aren't as bad as they seem and get a prognosis before I ask about the costs of all the goodies. I've wanted to get the buffer kit but was loathe to part with it for too long. If I have to send it to you anyways I might as well have you do all the cool upgrades.Where do I send it?RegardsDave
It's what we do
Dave, upper right hand corner of every comment there is a "Quote" button. Automatically will take you to the Post reply screen. You can delete some of the quote to shorten it, just make sure its inside the ] at the beginning and the at the end
Okay, that was 'just one thing'.....
