Subwoofer ?
0 Members and 1 Guest are viewing this topic. Read 6228 times.
chip
Subwoofer ?
« on: 21 Oct 2011, 08:43 pm »
I currently have two of Dannys SW-12B/PR subs run off of one A300 Rhythmik Audio amp.
What type of upgrade would it be going with say the SW-12-08?
cody69
Re: Subwoofer ?
« Reply #1 on: 22 Oct 2011, 12:13 am »
I was in the same position... had 2 of the "Classic" GR subs and converted over to the newer servo designs when they came out. The servo subs are a completely different type of bass. Really fast and tight -- I really like them for music. Here's a thread that has more details on this.
http://www.audiocircle.com/index.php?topic=77367.0
Danny Richie
Re: Subwoofer ?
« Reply #2 on: 22 Oct 2011, 02:50 pm »
New A370PEQ amps are still on back order and won't be here until the first of Dec. You'll need one amp and one SW-12-04 woofer. The quality of the bass, resolution and detail levels of the servo subs are in a completely different league.
chip
Re: Subwoofer ?
« Reply #3 on: 22 Oct 2011, 03:31 pm »
So the A370PEQ has to be used with the SW-12-08 I can't use the A300?
Danny Richie
Re: Subwoofer ?
« Reply #4 on: 22 Oct 2011, 03:36 pm »
The SW-12-08's have been phased out. I only came out with the 8 ohm version so that two woofers could be used with one amp. A new amp will be built with two amplification channels to accomplish this in the future.
I think Brian has a few A300 amps in stock that the servo system can be added to.
chip
Re: Subwoofer ?
« Reply #5 on: 22 Oct 2011, 06:46 pm »
So the 08 can be run off of one amp but if you want dual setup like I have now I would have to go with 2(04) subs and 2 amps?
I was seeing if there was a way I could resuse my current amp with dual subs..
Danny Richie
Re: Subwoofer ?
« Reply #6 on: 22 Oct 2011, 06:54 pm »
No, the new plate amps will be different. Think of it as a single plate amp, but with two amplification channels. One for each woofer. And I think the amps will be modular. So you can add a woofer and add an amp module. One set of controls though. That way you don't have to buy two separate and complete plate amps.
coachwoody
Re: Subwoofer ?
« Reply #7 on: 24 Oct 2011, 06:33 am »
Is that Brian from Rythmik? Do you know what he is selling these for? I have a small listening/home theatre room that I would love to put a Rythmik servo sub in.
Danny Richie
Re: Subwoofer ?
« Reply #8 on: 24 Oct 2011, 02:56 pm »
Yep, that's the same Brian. I don't think he has listed them for sale yet though. He has no amps for them yet.
corndog71
  • Some people call me Rob.
Re: Subwoofer ?
« Reply #9 on: 24 Oct 2011, 04:38 pm »
Would the 8" subs be compatible with the A370PEQ amp?
Danny Richie
Re: Subwoofer ?
« Reply #10 on: 24 Oct 2011, 04:49 pm »
Yes
chip
Re: Subwoofer ?
« Reply #11 on: 7 Dec 2011, 12:03 am »
So is there anyway to drop a 12-04 in my current box and seal the back piece up where the PR is?
This box is 1.2 cubic foot sealed box? It is 18" * 18" * 18" with 4 braces inside it I want to say.
On the Rythmik audio site is says - GR SW12-4 (for 1.6 to 1.8 cu ft sealed enclosure)
Danny Richie
Re: Subwoofer ?
« Reply #12 on: 7 Dec 2011, 03:30 am »
So long as it is well sealed then it should work fine.
chip
Re: Subwoofer ?
« Reply #13 on: 7 Dec 2011, 06:15 am »
What am I losing with the 1.2 vs 1.6 cubic feet for those subs?
Danny Richie
Re: Subwoofer ?
« Reply #14 on: 7 Dec 2011, 04:03 pm »
You are making the amp work a little harder to maintain that linearity.
chip
Re: Subwoofer ?
« Reply #15 on: 27 Dec 2012, 11:13 pm »
So did Brian ever release these amps?
I still never upgraded but recently I have been debating again. Right now I am just trying to price some things together.
I am still looking at the SW-12-04 Sub but was looking at some other options as well in the 15" range.
Danny Richie
Re: Subwoofer ?
« Reply #16 on: 27 Dec 2012, 11:19 pm »
Brian has not yet gotten these new amp produced.
If you are looking for the best quality and resolution then our 12" woofers are the way to go. If you are just looking for home theater applications and want as much output from a single woofer as possible then you might want to consider their 15's.
I also have one pair left of the SW-12-08 (8 ohm woofers) that will allow two woofers to be used with a single amp. First person to buy them gets them.
chip
Re: Subwoofer ?
« Reply #17 on: 28 Dec 2012, 09:15 pm »
Danny could the SW-12-08 be run off of my current A300 amp? or do you have to use the A370-PEQ<
Danny Richie
Re: Subwoofer ?
« Reply #18 on: 28 Dec 2012, 09:24 pm »
Yes they could.
chip
Re: Subwoofer ?
« Reply #19 on: 29 Dec 2012, 09:09 pm »
So with SW-12-08 -
1) Is there an advantage to running each sub off of its own amp?
2) What is the difference between using my a300 and running both vs. running them both off of a A370-PEQ?
