0 Members and 1 Guest are viewing this topic. Read 20058 times.
Meanwhile I have found a woofer with figures and response so good I barely dare to beleave: Precision Device DP.1550I made a scan of the datasheet => Looks like this could be a nice one for a system with only one woofer instead of two per side? And EUR 200 seem well OK...What do you wonderful people think about it and does anyone enjoy any own experience with it or other 15" PDs?RegardsTill
Yes, I plan OB. Do you think QTS is too low to be helped out by going active plus DSP? I was looking for high efficiency, low QES and low Mms : B/L ratio as well as high Xmax. I have heard several times that very high QTS meant reduced dynamics and precision in upper bass / low mids... Am I wrong with this or too naive?RegardsTill
How would a low-QTS driver (say, around 0.3) perform in an open baffle without H-frame? I expect early drop in low freq. Is there a realistic chance to come up with this by equalisation to get reasonable 35-40 Hz or will that lead to too muchg stress / excursion and unprecise performance? I have been hoping not to need a H-frame... (yes, the design...)
