The Vendetta Research SCP-2a in TONEAudio
0 Members and 1 Guest are viewing this topic. Read 11795 times.
TONEPUB
Re: The Vendetta Research SCP-2a in TONEAudio
« Reply #20 on: 13 Oct 2011, 07:45 pm »
It's certainly one thing to point out a products advantages and disadvantages, I don't see that as a negative review - and we do that on a regular.  We just reviewed the current John Curl Design, the Parasound JC2.  It has limited loading options, that might be a problem for certain end users, so we always try to point that kind of stuff out, so you can decide up front if it's a piece of gear you want to investigate.
I've reviewed and listened to enough gear in the last 30 years, that I can pretty much make anything sound bad if I haven't set it up properly or matched it up with synergistic gear and cables, not to mention the room interface.
So to just come out and write a purely negative review of something because the reviewer didn't like it, couldn't set it up properly (more common than you might think), or it wasn't a match with the rest of their room/system (even more common) is irresponsible in my opinion.
