0 Members and 1 Guest are viewing this topic. Read 10125 times.
Thanks! You think they would work under VMWare and Win7?
Anyone using an Air as a music server -- feeding a DAC?
Pick me! Pick me!Yes, currently using an 11" MBA as a server. USB side of things is good, but it has no FireWire. Therefore, USB dacs sound great. Not so much for the FireWire variety.
Right. No Firewire. So USB out to a DAC and one more USB port for a USB hard drive. I know there is optical out as well. I have heard some suggest that if using USB out to a DAC it is best to use a Firewire hard-drive (and vice-versa). Not sure if there is anything to that but that is not possible on the Mini.
I wonder if the next gen Air will have FW. That would be great!
Depends on whether the "minimalist" philosophy continues I spose. After all, if you need more stuff, get the laptop that has more stuff.
It is very unlikely that FW will be in the next MacBook Air.
