Sourcing circuit breakers
0 Members and 1 Guest are viewing this topic. Read 1109 times.
Gordy
« on: 22 Apr 2004, 10:36 am »
I'm looking for the last few parts needed for a 40a, 500va power supply and am hoping for your opinions on a specific circuit breaker make and source, it'll be used in chassis ala the BPT's.  Thanks for any and all help!
Gordy
Gordy
« Reply #1 on: 22 Apr 2004, 04:21 pm »
Just found out there is no such thing as a instantanious breaker, so I'll be using fuses after all...
EchiDna
« Reply #2 on: 22 Apr 2004, 11:30 pm »
it doesn't really answer your question, but....
there is no such thing as an instant fuse either buddy ;-) it does take time to burn through....
I use circuit breakers all the time for projects, I've got one in my john risch power filter for instance...
and I use a 30ms ELCB (Earth Leakage Circuit Breaker) for safety purposes, so when operating on 220 volt, 50 Hz power (as it is here in Singapore) the most I can get jolted by is a little over half a Hz of electricity before the thing trips and I'm safe. In effect, I would not feel a thing if indeed I was to get zapped because there would be no "zap", no short circuit at all, just a clicking button letting me know that there was an earth leak in the system somewhere.
