What most speaker makers don't know but should
0 Members and 1 Guest are viewing this topic. Read 6532 times.
Roger A. Modjeski
Re: What most speaker makers don't know but should
« Reply #20 on: 3 Oct 2011, 11:17 pm »
effective mass
Yes, we have a winner. Would you care to elaborate?
gnnett
« Reply #21 on: 24 Oct 2011, 05:14 am »
Roger
I am intrigued and bewildered by the topic and have toyed with the idea of both servo and ripole sub-woffers to match my acoustats, crossing over below 50Hz. Mainly because I have limited power to run the panels rather than major dissatisfaction with the bass quality.
Despite what you have said above and the "effective mass" answer I am still struggling with the F=ma. While mass does not change, I am not sure what a flat frequency response represents in terms of, is it constant amplitude of wave, therefore displacement, or is it constant energy, therefore area under time displacement curve? Please excuse my ignorance but for some reason I have either forgotten or never grasped what this is. Silly after over thirty years of fiddling with stereos.
Cheers
Gnnett
