0 Members and 1 Guest are viewing this topic. Read 11744 times.
Assume that you could do two identical measurements and only change one variable such as changing a single bass trap from one to another. And suppose you could measure a difference. Would you be able derive from the data which sounds better?
how does one go about conducting, what seems to be the gold standard, a null test?
You're already getting good advice, but I can add a bit. Especially since I see my name. A null test is not appropriate for measuring the improvement after adding acoustic treatment.
Is it not possible to play a 10 second file of music, record the file, then overlay each file for cancellation?
Not to hijack, but to hijack: Ethan, if you have a quick moment, would you please weigh in here??http://www.audiocircle.com/index.php?topic=98771.0 I plan on doing treatments as the next stage, or at least get things going. Neekomax I am also looking at your diffuser thread. ... back to testing thread
From a frequency response perspective only, yes.From a time perspective, how would you measure decay over time when you have a 10 second clip where the stimulus is constantly changing and being added...Also, how would one see changes in imaging from overlaying clips? One of those things that cannot be measured. Channel separation is not sufficient nor would it be measured in this type of test anyway.Bryan
It's easier if I reply here, so I don't forget to look in a section I don't usually visit for follow-ups. In fact, PM me if a further reply is needed. I'm hardly visiting any forums these days as I work on my book to meet the publisher's deadline.Anyway, you definitely want to face the top wall with the window as you sit, with the speakers firing toward the bottom angled wall. That keeps the front of the room symmetrical, which is what matters most. If you can leave the door open, that adds bass trapping in that corner. Though you'll of course need "real" treatment too.--Ethan
