0 Members and 1 Guest are viewing this topic. Read 18809 times.
OK, so I set the meter 1' from, and level with, the main driver and measured. All frequencies I measured between 50 Hz and I think I got as high as 1,000 Hz were within 1db on the meter. Although as I got higher in frequency, where I stood affected the reading a bit. IOW it doesn't appear to me to be the speakers. I'm still tweaking the speaker placement in the diagonal setup. It's actually pretty tricky to get the speakers set in the right spot because my room is not square so I can't really measure off the walls. I need to measure off the imaginary center line that crosses in front of the listener. My head right now is over 4' from the back corner and the speakers are out into the room more than shown in Doug's sketch #1.Doug s - Did you just drop the 2 speaker blocks randomly on the drawing to show a general idea for placement, or is there some formula/guideline? To give you an idea where I'm at - My left speaker is pretty close to where the "R" speaker is on the Sketch #1, and my chair is farther back towards the corner (about where the "L" is for the Left speaker).Thanks for sticking with me guys.neeko - I'll get the big speakers up there soon.
i did not use any special formula; i was simply trying to get a nice triangle-based listening situation between chair and speakers, that allowed for decent space behind the listening spot. if your left speaker and chair are where you say, then i assume the right speaker is now not on top of the old "chair" position, but moved up, so it's closer to the left speaker, as the left speaker has moved?and another thing regarding being out from the walls - while room/wall treatment is still necessary in such a small room, imo, the beauty of the angular layout is that, besides the listening position not being backed against a wall, you can get away w/the speakers being a bit closer to the walls, because the walls outside the speakers fall away from the speakers more than the normal layout. and the walls inside the speakers are doing the same, as opposed to having the speakers close to a normal back wall...also, didja try opening the closet doors when listening? (i assume they're some sorta accordion-type door, and not two simple swing-out doors)doug s.
I did reposition earlier today and the speakers are closer to the walls, more towards either side of the rack as opposed to being in the middle of the room. I think I'm getting close. Whereas before I listened and made myself not move the speakers to see if I could get used to it, with this most recent change it really does sound very good. I'm thinking there's a 50/50 chance I'll keep it like this for a while.
