Increase the size of Volume Slider control in Itunes Remote
0 Members and 1 Guest are viewing this topic. Read 947 times.
skibum
Hello,
I adjust the volume output of my DAC using the Itunes Remote app.
Does anyone know of a way or an app that can make the volume slider larger?
With big fingers it is difficult to use at times.
skibum
« Last Edit: 11 Sep 2011, 09:13 pm by skibum »
skunark
Re: Increase the size of Volume Slider control in Itunes Remote
« Reply #1 on: 12 Sep 2011, 06:04 am »
You can try the zoom features in the accessibility feature.  You can also use the white or silver apple remote
skibum
« Reply #2 on: 12 Sep 2011, 07:17 am »
I never thought of that! The handheld Apple remote can adjust the volume also... I think I will give that a try. Thanks!
