HIFIMAN HE-4's
0 Members and 1 Guest are viewing this topic. Read 3701 times.
Jason T
  • Enjoying the music
    • custom cables
HIFIMAN HE-4's
« on: 9 Sep 2011, 08:19 pm »
thanks to Tom I'm a HIFIMAN for life  :thumb:
I got these about an hour ago and couldn't even wait to build a cable to hook them up to my Sensation :) I took an extra long lunch  :nono:
I used our 4 conductor Quadraphonic speaker cable to build it with.
God I love these headphones ! :P :beer: :drums: :rock: :bounce: :hyper: :dance:
roscoeiii
Re: HIFIMAN HE-4's
« Reply #1 on: 9 Sep 2011, 08:42 pm »
Gonna sell those adaptors to other Hifiman owners?
Jason T
    • custom cables
Re: HIFIMAN HE-4's
« Reply #2 on: 9 Sep 2011, 11:48 pm »
I already build those just let me know what length you want and i'll shoot you a quote
[email protected]
on the HE-4's I had to cut off the 1/4" plug that comes on them and wire in a 4pin xlr plug so for those of you needing that done it will cost a little more.
I'll try to post a price list in this topic this weekend of various lengths.
I'm also going to try a few different types of wires. I'm thinking Auric hookup wire but that gets pricey quick.
I can use almost any wire you want.
eclein
Re: HIFIMAN HE-4's
« Reply #3 on: 13 Sep 2011, 07:19 am »
Jason--I have some HE-5LE's and a TWO.2, the cans come with both kind of cables in my case so I can choose 1/4" or XLR so I won't need an adapter. Do you make a box or converter so we can use the TWO's speaker outputs or do you think the one HiFiMan sells is a good choice??
http://www.head-direct.com/Products/?act=detail&id=104#
Jason T
    • custom cables
Re: HIFIMAN HE-4's
« Reply #4 on: 13 Sep 2011, 02:22 pm »
I'm making strictly extension cables for them however I like the adapter box idea that's cool.
I would say go with whatever is easier for you to use.
eclein
Re: HIFIMAN HE-4's
« Reply #5 on: 13 Sep 2011, 02:32 pm »
Jason, so is it OK to use the box with TWO.2 ? Nothing will smoke? Nothing will burn up before my horrified eyes?? :thumb:
Edit: Jason is it OK with the box to leave it plugged up to the Virtue say by banana plugs while using it with speakers with wire wrapped around post?? Can I set that thing up and leave it set up and just plug in cans when I want to do cans. I'll figure someway to turn speakers off in the room.
Rclark
Re: HIFIMAN HE-4's
« Reply #6 on: 13 Sep 2011, 08:06 pm »
Hey Jason, which headphones are those?
Jason T
    • custom cables
Re: HIFIMAN HE-4's
« Reply #7 on: 13 Sep 2011, 11:43 pm »
Read the title of my post  :o
OzarkTom
Re: HIFIMAN HE-4's
« Reply #8 on: 14 Sep 2011, 02:32 am »
Yep, Magnepans in a can. But since there are no cross-overs involved, the Hifiman and Audeze cans are even more detailed than the Magnepans.
Rclark
Re: HIFIMAN HE-4's
« Reply #9 on: 14 Sep 2011, 03:14 am »
 :oops: omg sorry
 heh. What a maroon.
Rclark
Re: HIFIMAN HE-4's
« Reply #10 on: 14 Sep 2011, 03:16 am »
 Then I completely understand Jason's enthusiasm. That must be awesome. I must have some.
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
Re: HIFIMAN HE-4's
« Reply #11 on: 16 Sep 2011, 09:52 pm »
Be sure not to bridge grounds on those 2 channels.  Some of the headphone adapter cords do it because most op-amps don't care.
Looks cool!  That will work too!
