Or built your own~ simple, cheap and a good performance.............
Or built your own~ simple, cheap and a good performance compared to high price cables which are basilly a designer series of bs, marketing bs and more bs! A good set of RCA cable shouldnt have to cost you an arm and a leg, $30 or $50 the MOST... Buy used, check out Audiogon.comBest of luck
if you want silver, it's hard to see how you can beat the price of these, even if you diy. (especially if you are wanting to buy more than one pair.):http://www.audiocircle.com/index.php?topic=98179.msg992513#msg992513these are nice cables, imo.doug s.
Yes Doug, you mentioned these already. I sympathize, I wanted my recommendation to be applauded as a vision revealed from on high. But in these threads where someone asks for product recommendations, invariably we get a cacophony of opinions, each one like seagulls on the beach hollering "Mine!, Mine!". Yet not one of us, myself included, has asked the OP about his system or preferences.
Q audio!!!!!!
If you can solder, this solution is the best I have found. I've had some high buck cables in my system and found these to be every bit as good to my ears. Cost is $8.50 for RCAs and about $.08 a foot for the wire per stereo pair. http://www.ebay.com/itm/10pair-Pure-Copper-OFC-Silver-Plated-RCA-Connector-Plug-/290571823037?pt=Speakers_Subwoofers&hash=item43a76e27bdhttp://www.ebay.com/itm/AWG-23-5-Copper-Magnet-Wire-H200C-High-Temp-/250819667777?pt=LH_DefaultDomain_0&hash=item3a66046741
