I34 power voltage ?
ricardojoa
I34 power voltage ?
« on: 31 Aug 2011, 10:10 pm »
Can the I34 be built for 220V?
Is it possible or advisable to integrated the I34 with AVR. For example, AVR pre out goes to I34 inputs.
Thank you
Audiovista
    • Vista-Audio
Re: I34 power voltage ?
« Reply #1 on: 2 Sep 2011, 09:27 pm »
Yes, the i34 is available for 220V.
Assuming AVR is Audio Video Receiver, then yes, pre-outs can go to i34's inputs. If variable output, then i34 volume control can be set to 3PM position, it seems to be an optimum for such an application.
Boris
