are these amps still on the good side ??
0 Members and 1 Guest are viewing this topic. Read 1884 times.
2bigears
« on: 30 Aug 2011, 08:20 am »
 :D  HELLO all audio dudes....  just wondering if a VAC 300.1 amp is still a well respected amp in the sea of new products that blow away value for dollars....i have a big SS amp right now and would love to get back to tubes....there is one on the Gon for 1/2 price.....any help thanks much.... :D :D :D :D
« Last Edit: 30 Aug 2011, 11:30 am by 2bigears »
KJ
Re: are these amps still on the good side ??
« Reply #1 on: 31 Aug 2011, 03:01 am »
Quote from: 2bigears
Definitely a solid amp based on personal experience.  Whether or not it's worthy of your dollars or considered a value is up to you, although $9K for a clean VAC 300.1 is the best I've seen advertised.
If you're used to big SS power, I'd take into consideration whether a single Phi 300.1 can drive your speakers adequately.  One might be enough for simpler pieces, but to drive a tougher load you might require two.  Such is the case with mine which has me re-evaluating my options (but that's half the fun).
