0 Members and 1 Guest are viewing this topic. Read 132333 times.
AJ, I am curious about the design decision to use a bass-mid/tweeter crossing at 200 Hz rather than a mid/tweeter crossing around 500 Hz?
you do realize that this is a coax driver, and its low end goes quite low? this way, the design can use a powered woofer almost like a subwoofer...
Many reasons, one of which is the diffraction losses of that sized baffle and the way it can be used to shape the total acoustic response (driver/filter/baffle). No need to cross the KEF driver higher due to it's inherent performance characteristics/strengths, ditto for the subwoofer.
Thanks for the reply which looks a bit like a manufacturers answer. Are you still alive on any of the DIY forums?
Hi Aj, what do you think about raal tweeter?
Would it be possible to integrate the raal in to this design working as a 4 way so the coaxial still remain but the raal will handle the higher notes.
andy, you obviously have not met aj, or read posts he's made to the forums - even tho he's technically a "manufacturer", he does this speaker thing as a hobby. he's an enthusiast first and foremost, and he will give you only straight answers. no gobbledygook here. he's about the straightest shooter you will find, here or anywhere, imo.
I have never met AJ but we have occasionally corresponded on other forums in the past. I suspect he will readily admit to being more restrained/responsible in his posting now he is a manufacturer and good luck to him. Whether that makes him a straighter or more bent shooter on an audiophile forum is perhaps debatable.
What do you think might be missing?
Did you understand it?
Again Andy, if you didn't understand, or did but need further info, feel free to ask. No secret sauces or magic in any of my designs. Just knowledge of the fundamentals and application.
Or feel free to use 500hz.
More on why you made the unconventional choice of a midbass rather than a mid in a 3 way.
The radiation pattern is one parameter but it is only one of a set which will of course be weighted by your objectives, constraints and other design choices.
I believe I understood what you said but I have yet to weight the significance which requires the comparison of a few simulations.
it's debatable, only if you like to argue. i have been following aj for a long time here on a/c, and and, w/o a doubt, you won't meet a straighter shooter, mfr or otherwise. if he shows restraint/responsibility, it is not because he's not a straight shooter, but because he may be more cognizant of not wanting to insult others when he knows they're full of it. i have found it pretty easy to read between the lines, most of the time, tho... ymmv,doug s.
Well, I am a manufacturer...
