0 Members and 1 Guest are viewing this topic. Read 7840 times.
Also, would you have a recommendation as to a good place from which to order the MR caps?
Thanks for the tips Jason. I might give this a try, but I’m still not 100% confident in my abilities .May I ask what kind of soldering iron you recommend for this type of job? What wattage would be appropriate?Also, would you have a recommendation as to a good place from which to order the MR caps?
Hello,I am about to buy a secondhand m901 and i want to use it only above 80hertz . I wanna replace the 100nf with a russian paper in oil and maybe i will try a teflon from russia too. Both can be found in a 200 volt version and i think the smaller the voltage the smaller the cap and the less degradation it will have on the signal passing through it. I think i did read it is possible to use the switch to compare between 2 100 nf caps when you are sure you only want to use it above 80 hertz. The best way to solder is from the bottom side of the circuit. BUT how easily can it be reached? Do i have to desolder a lot of things besides the caps to do so?Many thanks in advance, Edward
Hello Tenantman,I will receive the m901 without power supply . The previous owner did use it with batteries.In the past i did have an hiraga 30 watt class a transistor amp that i did use with a choke instead of a .22 ohm resistor in the power supply. Because i have some potted 0.1 henry 1.3 ohm and 1.3 amp chokes in stock. I did decide to try the m901 with a choke input power supply. So just did have to buy an EI 300va transformer. It will be rectifier , choke ,cap 10.000mf or less, another 0.1henry choke followed by another cap. This outboard supply weighs about 10 kilogrammes one more reason you don't many transistor amps with chokes.The caps changing can be hit or miss too. I have quiet a lot of candidates so i wanna make a change to the m901 housing that will allow me to change caps easily.First i will have to wait for the m901 to arrive. Maybe the standard cap will sound already good.Choke input usually gives an amp an easy sound, effortless. BUT i never heard a virtue amp before.Sincere greetings, Edward
