0 Members and 1 Guest are viewing this topic. Read 12211 times.
Definitely a dedicated line with a receptacle just for the one circuit. If you can do two receptacles on two circuits even better.
How would one utilize two receptacles on two circuits?
Any specific instructions I should give the electrician?
Thanks Phil. How would one utilize two receptacles on two circuits?
If you want to be a bit extreme, you can ask the electrician to mount a separate circuit box from the mains...
Can anyone give me a ballpark cost for installing a dedicated line? I realize it will vary by geography, size of house, condition of electrical circuits, but please give me a rough estimate.
Greetings everyone,I am meeting with an electrician later this week to discuss a household project. I currently plug my 2-channel audio gear into a power strip (Wiremold) which is then plugged directly into a wall socket. I'm considering upgrading the socket and/or having a dedicated line put in. Suggestions? Thanks
What do you think a dedicated line(s) are going to accomplish for you? There are lots of noise makers in your home already, and they are connected to your panel. Adding one more branch circuit will solve nothing, except for ampacity. I personally think you are better off treating what ever symptoms you have at your local outlet, or do you not have any symptoms?The dedicated line is way over the head hype in my opinion and generally does nothing to solve most home bound noise inducers, like furnaces, refrigerators, AC units, lighting dimers and stuff like that. It just isn't that magic pill to cure all that everyone suggests. Besides, there is plenty of noise coming in from the street. How are you going to take care of that? The dedicated line wont fix anything like that.Wayner
