How to update iPad OS?
Dracule1
« on: 20 Aug 2011, 05:59 am »
Hi, I can't figure out how to update my iPad 1 to the lastest version of the OS.  Can someone show me?   :scratch:
Crimson
Re: How to update iPad OS?
« Reply #1 on: 20 Aug 2011, 09:16 am »
Plug your iPad into your computer and start iTunes (if it doesn't start automatically). In iTunes, click on the iPad icon on the left hand side under Devices. iTunes will then tell you if there is an update available for the OS running on your iPad. If so, follow the instructions to update it.
Dracule1
« Reply #2 on: 20 Aug 2011, 11:24 pm »
Thanks!  I was successful downloading the latest OS but I'm running into another problem.  My iPad remote control apps for iTunes and Fidelia no longer starts when I click the icons.  Am I missing something here? :scratch:
Crimson
« Reply #3 on: 21 Aug 2011, 02:38 am »
Do a hard reboot of your iPad (press and hold the Sleep/Wake button, slide to power down; press and hold again to power on). In most instances, that should work. If not, it means the developers of those particular apps haven't updated their apps to the current OS rev.
Dracule1
« Reply #4 on: 21 Aug 2011, 09:28 am »
I had to delete the remote apps and reinstall them.  That fixed the problem. :thumb:
BooGappa
« Reply #5 on: 22 Dec 2011, 06:06 am »
I guess it depends on what you do with the iPad.  Currently, we use this as solely a web surfing device.  We have no movies, pictures, music on it.  I use my iPod for music.  We don't play games with it.  I assume in the future, we'll use the iPad for movies and maybe pictures, but we'll see.  I have a 3TB drive with all my movies, pictures, music, home videos on it; we just bring my wife's laptop and watch everything using it.  For us, the 16GB is plenty of space right now.
ratso
« Reply #6 on: 28 Dec 2011, 05:43 am »
strange, dracule, because the EXACT thing just happened to me this weekend. i also updated my ipad 1 for the first time and remote stopped working. also deleted it and re-downloaded and it works fine.
