0 Members and 1 Guest are viewing this topic. Read 9085 times.
The ability to use plug-ins is a big plus for me with Pure Vinyl. I can't really help with free plug-ins, but I have been using IK Multimedia's Advanced Room Correction plug-in and have been really happy with the results.On occasion I have also used compressor plug-ins or eq to create a "loudness" function like on an old receiver.I have a fair number of plug-ins from video editing hardware and software, so I haven't had to search for free alternatives.Jim C
I'm also using a pro-audio fire-wire interface as a psuedo pre-amp, so I can have 4 inputs in addition to iTunes.At some point in the future, I'll use Pure Vinyl's crossover feature and the 4 stereo output channels of the audio interface to create an active crossover set-up on my speakers.Jim C
Finder switches back to iTunes window between tracks, annoying when posting to AC (fix for this?)
Try turning off the "Notify when busy loading into memory" option.
Hi Neekomax, Can you tell me where you downloaded your plug-ins and exactly how you access them in Pure Music? I want to go down the same path but am a Mac newbie.......also if anyone else has any other software equalizer recommendations I would love to hear them.
FabFilter Pro-Q is really great.http://www.fabfilter.com/products/pro-q.php-Jim
Thanks Jim. Are there any programs in the $100 range that are maybe less for editing and more for listening? Anyone else with recommendations?Thanks,Morgan
Thanks Jim. I will try the free demo for sure. Do you integrate the program into itune or Pure music or is it independent?
