0 Members and 1 Guest are viewing this topic. Read 23938 times.
wayner, this link, #4?http://www.mcmaster.com/#adjustable-feet/=doapqm
what about this for the platform?http://www.adonacorporation.com/multi-element.html
Thank John...listening to the rig right now, albeit low volume due to sleeping daughter, it sounds quite good! I just checked the mounting distance, 258mm, to make sure that the cartridge and everything is set up right! still breaking it in, though there's not really any breaking in since the platter and bearing are the ones I used on the TNT. Anyways, have the TNT plinth for sale as well as others, if anyone is interested! Please see this link!http://www.audiocircle.com/index.php?topic=97548.msg979518#msg979518
Sonny, before plating or other have you considered counter sinking the bearing housing to decrease the gap from the platter to plinth. I don't recall who maybe TTweights at RMAF where I heard getting that gap smaller made a big differance in tuning the table.Brad
I'm assuming that 258mm is from spindle to tonearm pivot? So if you wanted to put your cartridge in a Lofgren B, then you would use 15.422mm overhang, using the null points of 70.285 and 116.604.I understand why you took the tonearm and separated it from the plinth. However, that now makes the location of the arm pivot in relation to the spindle a bit ambiguous. I wonder if bill can make you a spacer block so that you can always set the arm's distance at what you want? From the top view looking down, it doesn't matter where the arm is (angularly), but you and I both know that maintaining pivot to spindle distance accuracy is very assuring when doing cartridge alignment.(just a suggestion) Project still great!!!!Wayner
Tuan, Do you really hear a difference with the 10.5" arm with either of the two tracing technologies: Lofgren B or Baerwald?Hell, I'm with Well Tempered on this...once you get to 10.5" arms...rigidity throughout the length of the arm is FAR more important than overhang or tracking technique. With a 10.5" or longer arm the argument for one type or another is nearly (perhaps not entirely) moot. With 9" arms, one can have a preference that matters as there is so much wanting in tracing distortion by the 9" arm itself. John
I was thinking about make a custom platform with a counterbore (about 1/8") for the armpod and plinth....they would be basically just a touch bigger than the pieces so they would fit in perfectly...but I don't have the tools to do such a thing, just a router is needed, right? Tuan
...especially in the inner grooves...there's just less "spitty" and "sibilance" with the Baewald vs the Lofgren...Tuan
