0 Members and 1 Guest are viewing this topic. Read 23892 times.
I use a similar product called Flitz and it cleans (and polishes) the same way, with a bunch of black residue left on the polish cloth.I was just thinking that there are lots of motorcycle shops that have lots of stuff chromed. It might not be as bad as you might think for price. Someone out there has to do it for these small custom shops.Wayner
I figured since the base was static I would not be generating any interference.
Wayner, there must be, but first I need to build or buy a shelf that can level, sell of my remaining stuff from the TNT table and sell of other stuff!
How about drilling and tapping three holes on the bottom for threaded cones? They can be used for leveling without having to move the entire shelf or stand.What are you going to sell?
There is no need for cone feet on this unit. At that weight, all the cones would do is damage things.Wayner
Looks impressive. Very nice job. I assume that the platter itself is finely balanced so as to not introduce any wobble while spinning? If plating doesn't work you could potentially opt for painting, but I like the raw metal look of this. As for a platform, metal can ring, even something of this mass, so I would suggest some wood (maple) and possible something with potential damping properties like Ginko Cloud-like clone underneath it all.
Beautiful table!!!It would probably be easier to devise a way to level the shelf or support, rather than the table. That's how I'd do it. I think cones with threaded bolts, even heavy duty ones, won't work. Even with all that weight it would probably wobble if you used them to level. Level the shelf and save yourself a lot of grief. Regards,neo
If my math is right, I'm betting that with a thick maple base, that the whole thing is going to weigh somewhere around 200 pounds. That is 50 pounds per foot. I think you need to move to the "industrial" sizes. 3/8-16 threads on swiveling, machined pads, for the feet. 3/8"-16, wide flanged "T" nuts for the bottom of the maple base, and you should be good to go. Look at McMaster-Carr for the feet.Wayner
