0 Members and 1 Guest are viewing this topic. Read 19322 times.
Most current preamps have remotes.
Was just curious to see if audiophiles value the remote as a feature, or if it's not considered necessary.]
Yep, you don't need lots of power if you are not going to use it. 25 watts is enough power for the average listener.
I have heard that extra headroom is needed because of transient peaks in music.
A remote is a must to adjust volume almost for every song so you don't get blasted out of the chair.
Public Service Announcement: Extended exposure to more than 85 dB will cause permanent hearing loss and possible lifetime pain. “Realistic” spls is a purist goal, but should definitely not become a way of life.
Wrt remote, my digital path uses remote at the computer. My analog path currently has remote but in the next version probably won't, in the interests of improving the quality (and keeping in budget). It's not like to you can fast forward or rewind with records anyway, so I'm thinking (hoping) I won't miss a remote too much there.
Roscoeiii makes a valid point too, that there is an output “sweet spot” where a pre-amp (and a power amp) works best. With two sets of volume controls in your system you’re free to optimize both. Note that buffer stages provide the impedance matching without a gain stage. Note that Eastern Electric offers a “BBA” (tube based buffer with two sets of volume controls) in one component.
Remote at the computer? For volume? Isn't that a no-no ?
So it is true that many manufacturers skip the remote control when designing quality components?
