Bryston Drive Enclosure
0 Members and 1 Guest are viewing this topic. Read 36743 times.
SHV
Re: Bryston Drive Enclosure
« Reply #160 on: 18 Feb 2012, 01:16 am »
Somewhat OT but after transferring my music files to the OWC, my play lists are listed but contain no tracks.  If they are lost, not a problem, but I can't figure out how to eliminate the names of the empty play lists from the "play list" list.  Suggestions??
skunark
« Reply #161 on: 18 Feb 2012, 01:39 am »
I took a peek at the playlists on my BDP and unfortunately they include the HDD volume name.  Which is probably why they appear blank to you now.
Assuming you kept the same directory structure between HDD with the music, you might try to make sure the HDD names match.
If that doesn't work and you don't mind a little command line action, you can tweak and run the following sed script.
sed 's/OLDHDDVOL/NEWHDDVOL/' oldplaylist.m3u > newplaylist.m3u
Where OLDHDDVOL is the old HDD volume name and the NEWHDDVOL is the new one.   The playlists are stored at /mnt/img/playlists
SHV
« Reply #162 on: 18 Feb 2012, 02:36 am »
Thanks..that is the problem...(there's a snake under every rock!!)
