Warpspeed Optocoupler
0 Members and 1 Guest are viewing this topic. Read 143995 times.
guest1632
  • Guest
Re: Warpspeed Optocoupler
« Reply #440 on: 17 Mar 2012, 11:20 pm »
Ray,
I had similar worries.  What I got back from WarpspeedCE was that using the battery was important.  I can tell you, it hasn't been an inconvenience in my system at all.  What I did was spend a little more on a battery that I worked with WarpspeedCE on selecting.  This has a couple of advantages:
First, it has never run down. I have measured it after a month of extended listening and it has always been nearly fully charged.  I learned that more frequent recharging rather than deep cycling the SLA batteries is preferred, so every few weeks I recharge it while I am at work (I have certain "long" work days that last 14+ hours so that is when I charge the battery...disconnected from the WS).
Second, I know I bought the right "type" (both in type of battery and in connector style).
Third, WarpspeedCE made the power cord with color coding for the tabs so it is simple to make sure you have the polarity right.  And since it is a quick disconnect on the back of the WS, I never removed the power cord tabs.  Very simple and worry free.  You can see in the photo that the battery has a manufacture's "red" positive marking and the power cord is color coded "red" for positive and "black" for negative.
Here is a quote of my charging comments and batter type from earlier in the thread, if that is helpful:
Best,
John
Hi John,
Thanks for the info on the SLA battery. In the meantime, both my questions stand unanswered. Thanks for the color coding which I cannot see. My wife can. But i wanted to in the very short term try this with a wallwart of 12V 300MA or 500MA. I was concerned about hooking this up backwards. I could then get the battery and charger, and in between usage of the battery, I could use the wallwart. Anyway, just a concern.
Ray Bronk
InfernoSTi
« Reply #441 on: 18 Mar 2012, 12:45 am »
Sorry I misunderstood.  It was recommended not to use a switching power supply but that would be for WarpspeedCE to explain.
Best,
John
Warpspeed CE
« Reply #442 on: 18 Mar 2012, 01:13 am »
Hi, This may seem like a stupid question, ... here goes. I am thinking about getting one of your couplers. If I happen to wire the battery or 500MA 12VDC backwards, I know the LEDs won't work. Will this damage anything else?
Also, I think I asked this before, and received no answer to this. You say the voltage requirements for this coupler is between 12V and 24V. If I raise the voltage to say 18V assuming I am using the same like a 500MA wallwart, will there be any differences here?
Ray Bronk
Ray,
The 'Squid (control circuit) will not conduct if the polarity is reversed. I suggest you do not do this deliberately just to find out -as this voids the warranty, and so with plugging-in an AC supply which definitely will break it. With a voltmeter and an ohmmeter, no way you will still reverse it...otherwise for your safety and that of the equipment have someone technically capable do it. Labeling and double-checking your work before plugging-in will also prevent accidents. 6V thru 24V will work.
Battery power is still the best source of DC power. SMPS or even linear PS will still have spikes, ripples, and noise artifacts that will couple to the LDRs. I recommend you acquire your SLA battery/charger before you receive your unit. If you don't mind using alkalines, which I do use...I can also build a 4x 9V battery harness on request.
guest1632
  • Guest
« Reply #443 on: 18 Mar 2012, 05:13 am »
Ray,
Hi,
"Let me make this abundantly clear." Remember who said that? I have no intentions lol to deliberately plug in the supply backwards to see what would happen. I do know the LEDs wouldn't work. That won't damage them. I do wonder if anything else would be damaged. That was kinda my  question.
Now as for my other question, is there an optimum voltage to operate the coupler? Besides the 9V and 12V you have anywhere up to the 24V figure. if not, then this is strictly a current thing, and the voltages don't matter? It just can't go below 6VDC.
How long does the 9V supply last versus say a 12V stack of D cells?
That was all I was asking. The wallwart idea was at best a tempary idea.
Ray Bronk
Warpspeed CE
« Reply #444 on: 18 Mar 2012, 07:24 am »
Ok, I meant it more as a precaution for everyone who reads thru our posts. Usually one's questions are someone else's too.
Anywhere between 6V to 24V is optimum dc voltage...will not affect performance. I've tried listening with 9V and 12V battery supplies but can't tell the difference. I've only bench tested with the other voltages like 6V, 18V and 24V.
I've had my (8x 1.5V)x2 Duracell alkalines for 13 months now and the reading today is 11.11V. For the 4x 9V at 3 hours daily use on a V4, I expect it to last 6 months or more. I say forget about the wallwart...:)
guest1632
  • Guest
« Reply #445 on: 18 Mar 2012, 12:58 pm »
Hi Warpspeed CE,
I kinda figured that was the case. When it comes time to buy, I'll discuss with you about the 8 D cells and there box to put them in and how to properly connect them if necessary.
Ray Bronk
Warpspeed CE
« Reply #446 on: 10 Dec 2012, 04:59 am »
Hello ACers,
To resuscitate this thread, would it be more appropriate to relocate it to "The Commercial Zone"? Anyway the Warpspeed is not considered "Cheap and Cheerful" anymore as the kit is no longer offered.
If it requires the the thread starter to request such, I would then respectfully request thru RClark.
Also by being at "The CZ", I won't have to think twice if my postings have promotional content? Please correct me if I got that wrong.
Rclark
« Reply #447 on: 10 Dec 2012, 05:42 am »
hey yeah, you know, I would certainly think a thread over there, or this one, would be neat. I'm still very much loving mine. You should consider another tour with different members. Fantastic device.
djbnh
« Reply #448 on: 10 Dec 2012, 11:12 am »
Plays very well with tube amps.
Letitroll98
  • Too loud is just right
« Reply #449 on: 10 Dec 2012, 04:44 pm »
You have to register as an Industry Associate to post about your products in the Commercial Zone.  There was free trial period in September, but a monthly subscription of $20 was targeted.  Check with JohnR about whether that has kicked in yet as I'm seeing a couple of threads started by Industry Participants and regular members there after October.
As far as moving the thread, I'm fine with whatever Rclark and WarpspeedCE decide, however I would think it to be confusing and counterproductive to move this thread which was about building a kit that is no longer offered.  Perhaps starting a new thread(s) about various products you manufacture might be more productive.  Typically threads like this just die out from lack of interest.  Sometimes they're revived by people still doing a build or troubleshooting a build, such as the $175 amp thread, so you might think about leaving it here in case that happens.
Warpspeed CE
« Reply #450 on: 11 Dec 2012, 12:37 am »
Big thanks guys! Please enjoy some more...
Letitroll98, thanks for the info...since I'm not about to be in the Industry full time anytime soon, we'll just keep things as it is then.
I always try to keep things updated at diyAudio.com so anyone with questions can post there too, email/pm thru AC or diyA. I can freely answer at diyA without having to worry about content and such.
Thanks for hosting a thread here though...
Warpspeed CE
« Reply #451 on: 14 Feb 2013, 07:21 am »
I'm saddened to learn that the fine craftsman from Oregon who took on making the Warpspeed front/rear panels has passed away. For privacy reasons I won't state his name here as he is not a member. I'm proud that his work resides with my work and is being enjoyed both visually and aurally around the world.
Rest in peace KMK...
In light of the above, I'm looking for an equally fine woodcraftsperson who is willing to supply in small batches...please pass it on also if you know someone. I can be reached thru AC by PM or email. Thanks!
Christof
« Reply #452 on: 14 Feb 2013, 04:21 pm »
We could do these in my shop.  I did similar projects a while back for owners of the Promethius TVC units.
Warpspeed CE
« Reply #453 on: 14 Feb 2013, 06:45 pm »
Thanks Christof, I just replied to your email...
InfernoSTi
« Reply #454 on: 14 Feb 2013, 07:47 pm »
I am proud to have his work in my home...and it is more meaningful now.
Rest in peace indeed....
John
marc513
« Reply #455 on: 3 Apr 2013, 04:23 pm »
        I just wanted to post a few thoughts on Allan's wonderful Warpspeed  I love it in my system . I only have two sources a Mac Mini computer with a Ultra Fi Musicstream DAC  and external hard drive with 23000 songs . My analog setup is a Basis 2001 turntable , Graham 2.2 tonearm, Dynavector XX2 MK2 cartridge and 1600 records. This feeds a Aesthetix Rhea phono stage then on to a NAT SE2SE  SET tube amp with 211 tubes. I use all Ridge Street audio cables [ power cords , interconnect , phono and speaker ] love them also . The speakers are from North Creek Music Systems when they made kits I have the Manifest model a MTM design with Scan speak woofers and a pair of ribbon tweeters one front one back side. I had the cabinets made by a local wood worker who did beautiful work with a waterfall bubinga wood . The room was built just for music in the basement of my home its size is 17  X  24  X  7.6 the room size was picked by the speaker designer . I have to say in my system a passive pre works wonderful i have never had better sound the first records i played gave me goose bumps and i had tears in my eyes . I can think of no better compliment to give Allan for his Warpspeed  just great . I would say if a passive works in your system give it a try you will love it and it is also beautiful to look at. Allan is just great to work with he keep me updated on the build progress and the packing for shipment was great also Thanks so much for a great product . Allan feel free to quote me if you like or e mail me with any questions  again thanks for letting me get closer to the music..
marc513
« Reply #456 on: 3 Apr 2013, 04:29 pm »
        I will post some pictures  later I have to go to work now as above feel free to use my pictures if you like .
               Thanks  Marc   [  marc 513   ]
Warpspeed CE
« Reply #457 on: 6 Apr 2013, 06:42 am »
It was my pleasure building a V4x2 for you, Marc. You were kind enough to allow me to send my remaining front panel to Terrawood as Chris needed one to create a template. You were also patient enought to wait for me to get it back that added another week to get completed. I'm happy that you like the Warpspeed very much...
I appreciate your kind words and compliments. May you enjoy your system for years and years to come!
I'm looking forward to pictures of what sounds like an impressive music room with an equally impressive music collection...
Rclark
« Reply #458 on: 6 Apr 2013, 08:39 am »
Hey, just wanted to let you know I am still loving mine. Mine is a kit version built by Trung here. It is definitely a unique feature of my system.
I'm still pretty new to the hobby but I rather like my system of a great cdp, your LDR, Ncores, and modded planars. I am constantly blown away by the sound.
Warpspeed CE
Warpspeed pilot on snooze...
« Reply #459 on: 6 Apr 2013, 10:56 pm »
This is not something out of left field for me but has been brewing for some time now. Due to what I'm sure now will be increased workload at my day job in the coming months I will not be accepting new orders at this time. Building new Warpspeeds will be put on snooze indefinitely while I concentrate my efforts on the job at hand. Gotta satisfy the bosses.
I might come up with a very limited number of builds per year just to keep it going but right now I'm not sure -we'll see. Just keep an eye on the thread at diyA as that is where I update as needed.
Thank you to all who have been following this thread, I'm quite happy how it turned out -I still can't believe interest would be this much. For those who now own a kit or a fully-built unit, enjoy! If used as intended it will last a lifetime...or more.
Ps: Thanks Rclark. Enjoy it!
