Huh.... well dang Doug, I'll try out the Neko but looks maybe another area ($) I can squeeze into maybe something more important. If it doesn't rip the dac in my cdp a new one I'll be impressed. Shoot, might just buy another XDA-1.
Make sure the DAC you buy will drive your amp. The Neko only has a 1v output. Very few amps these days are driven to full output by 1v. Most take around 2v. You might want to consider the Bryston BDA-1 which has a superb discrete class A output stage.
...i do believe in clean power - my digital was improved w/isolation transformers - at the wery least, use one for dac and another for transport...
1v output is quite low to be used w/a passive preamp...doug s.
..and I guess I'll be evaluating the Neko at lower listening levels then ?
Lol, you're right Doug. It seems there's inflation everywhere huh? Even in the cheap and cheerful forum we buck against the limits. Clearly though, we should consider the Warpspeed and similar ldr's to be a supreme value.
...And because I sincerely don't have the slightest desire for a remote, let me say that I run my front end through a Bolder Modified Touch that allows me to click "pause" and change songs, etc remotely. But I don't use the volume on it whatsoever. I just set the volume for what I want at the beginning of the session and then, if an album is low/high, I get up, walk ten feet, turn a knob a 1/4 inch, and sit back down. Typically I get a Scotch while I'm up and then start the album over so I can listen all the way through. I never touch the volume except by album and rarely that...
