0 Members and 1 Guest are viewing this topic. Read 144925 times.
I think thats what I'll do, since it's now permanently attached. I'll run it off charger, and simple matter to plug the charger in at night.
Who's using a depleted battery? I don't wanna repeat all that over again for a third time.
For an elegant solution, make a 2 into 1 connection so that you have a harness on the battery that has 2 + and 2 - coming out of it. Put connections on the end for the warpspeed and the charger. I would just reterminate the charger with a connection that is better for your situation...In my case I terminated the charger cord with a neutrik powercon to go to my battery box...
I have an emotiva mps-1 which I am using with the traveling WS neutrino since my Rogue tube amp developed a problem. The mps-1 has 20K ohm input impedance. The WS has no problem driving this.
Bottlehead 2A3 amp with no volume pot (uses 100K resistors to ground). Amp lightly modified with Mundorf silver/oil caps at parafeed and coupling. Lovely.John
Virtue 2.2 highpassed with ClarityCaps on batteries. The combo is beyond superb.
Were you using the Emotiva amp with or without the Dodd buffer? If you have a chance, see what difference you hear with and without the buffer in place. If the Warpspeed is driving the 20K Emotive without a buffer and still gives the same amazing results, that is awesome!
