I actually wrote this in another Circle, but thought it might get buried or overlooked by some who might benefit from it. It is about the use of some of the "silver treatments" out there. I have had an exceptionally good result with them. I have had experience with both SilClear ($35) from MapleShade and Super Silver Treatment ($69) from Walker Audio.YMMV
Do you just brush it on ?
Bound For Sound's MGD has advocated putting a little oil or grease on your power plugs for awhile, claims it eliminates "micro arcing" btwn the outlet and the plug.I just received a tub of the SilClear myself, and will hopefully get some time to apply it this weekend. I probably won't get to cover everything, so John, you think that the power plugs got the most benefit? Did you just do the prongs that go into the wall, or did you also do the IEC prongs on the amp/BPT itself? Did you bother with the little fuses on the CineNova?
Check out this board entry:http://www.hawthorneaudio.com/forums/viewtopic.php?f=4&t=2146
Its been brought to my attention that contact enhancers (no specifics need to be mentioned) have adverse effects on the sonic performance of MAC Palladium cables. They rendered a flat sound with excessive emphasis on mid and upper range, even exhibiting harshness. Removal of the contact enhancer returned the sound to its wonderful self.
“If I discover within myself a desire which no experience in this world can satisfy, the most probable explanation is that I was made for another world.” C.S. Lewis
Hey djbnh...Cool signature line!Quote“If I discover within myself a desire which no experience in this world can satisfy, the most probable explanation is that I was made for another world.” C.S. LewisI definitely relate to it Robert
