0 Members and 1 Guest are viewing this topic. Read 28634 times.
Thanks! A friend came over this weekend and we watched the new blu-ray release of Star Wars (IV). Wow - combined with the quality of the video and sound it was like watching it for the first time.
Just fantastic Ruben!
Two words:Sealed version?
Is there a sealed version available?
As far as performance goes, how do the 2 versions differ??
The only difference will be low frequency extension.
With the ported version extending lower??
Okay. The sealed version will be 2.5" shallower than the ported and have a solid rear baffle. All else will remain the same. For the ported version 6"- 8" is the minimum recommended clearance range between the wall and ports.Thanks,Ruben
Might as well answer the what to spend the tax refund on question early.
Hi, Great looking speaker. Would this be a good match with Onix Ref 3's? I was looking at upgrading my Ref 100 with Ninja components but this speaker has my attention.
Check your PM.Furthermore, I'll be needing one built by you for our HT at home so I'll check back with you later once your backlog is lighter.
Hi Eric,Though not in stone yet, Satin Rosewood will likely end up around $1500.00. I have a couple more Piano Black LS-C's to get out the door and then I'll be ready to get crackin' on them Rosewoods. (Piano and Satin) Best,Ruben
