Why single/wide bandwidth
0 Members and 1 Guest are viewing this topic. Read 24905 times.
Richard in Idaho
« on: 29 Jul 2011, 02:41 am »
While on a trip recently I listened to a pair of Klipsch RF-7 IIs. Really liked the sound.
But, I have been reading here and other sites about single driver/wide-bandwith speakes. Omaga/Hoyt-Bedford, Zu, and Tekton mostly..
Other than cost, why would prefer one of these three?
One thing of note. I am 71 and my hearing falls off around 8,400 Hz.
I hope to take a trip to the SLC area soon and check out the Zu and Tekton.
doorman
Re: Why single/wide bandwidth
« Reply #1 on: 29 Jul 2011, 04:08 am »
Hi Richard: Single, wide range drivers can be an excellent choice, especially for those of us with "older ears." The coherence can be very addicting, as well as the ability of many SD designs to disappear.
The absence of a xover can be quite a revelation.
They offer their own compromises, but the right driver in an appropriate enclosure works for me.
Happy Listening!
don
« Reply #2 on: 29 Jul 2011, 04:07 pm »
Midrange is king (at any age) and that is where single driver designs shine.  As doorman indicates coherency (especially nearfield) is perfect.  Imaging (single point source) is ideal.  And by default single drivers are "active" (one channel of amplification per driver) which adds dynamics, allows the amplifier to "see" the simplier load easier, and increases depth/volume of bass significantly.
Crossovers may be necessary, but are always evil, especially in the midrange frequencies where the ear is most sensitive to phase mix ups.
If you've read through this circle you'll find no concensus on a definition of a single driver design.  The purists say one driver period, but that's hard to find that provide satisfying bass without sacrificing the highs.  Some say woofer with tweeter is OK if the tweeeter only has a capacity to protect it (no "real" crossover).  Others look towards a smaller driver with a subwoofer added.  Etc/etc.
For older ears I'd lean towards larger drivers that can handle more bass better.  OTOH smaller drivers "beam" high frequencies less.
The downside of single driver designs is that they don't handle  loud/complex types of music as well as muli-driver designs.  There is no perfect loudspeaker.
Also search for Planet10 and brinesacoustics.
IronLion
« Reply #3 on: 29 Jul 2011, 08:29 pm »
I recently got a pair of John Blue JB3's and a Kingrex T20 amp for my desktop computer setup.  It is the first single-driver system I've had that I really enjoy (had a pair of old Zu Tone monitors a while back that never really got my attention, I think Zu's designs back then for the Tone monitor, wasn't quite up to par), and I've been so impressed with it that I am pretty sure I will only own single driver speakers from here on out.  The coherence in the midrange that other posters previously mentioned is simply addictive.  If you're interested, I suggest you try pairing these two together by finding used ones on Audiogon- the investment isn't that bad, but the sound is really good, and everything single drivers are known for.
Duke
    • http://www.audiokinesis.com
« Reply #4 on: 2 Aug 2011, 07:19 am »
It is possible that the oft-cited coherence advantage of a single driver has more to do with its relatively benign off-axis response than with its superior phase response.
My understanding is that the ear is relatively insensitive to phase anomalies.  Not that they aren't audible, but they are a relatively subtle effect.  In contrast, frequency response anomalies are generally a lot more obvious.
Most two-way systems have a pronounced off-axis response glitch in transitioning from the midwoofer (which is beaming) to the dome tweeter (which has a wide pattern).  Since most of the sound that reaches our ears in a normal room setup originates with the off-axis response, we hear that glitch, and it's right smack in the crossover region.  I believe this response glitch is far more audible than phase shift in the crossover region.
Fullrange drivers do not have that sort of off-axis response discontinuity, so there is no corresponding frequency response glitch for our ears to take notice of.  I believe that one subjective effect of this is superior coherence.
neobop
  • BIRD LIVES
« Reply #5 on: 2 Aug 2011, 12:17 pm »
Interesting theory. I completely disagree. We are very sensitive to phase anomalies. When a set of speakers exhibits phase differences we get accustomed to the sound. When the phase differences go away, it sounds much better. But it's not only phase that a crossover messes up. The fidelity of the electrical signal is compromised. Send a square wave to a mid/woofer through a crossover and there's no chance that the speaker output will look anything like a square wave. Remove the crossover and a good woofer will output something that resembles a square wave. Phase effects sound localization (imaging) and coherence.
Virtually all mid/woofers start to show off axis response differences around 1 to 2K region. One of the advantages of a multi-driver system is optimise off-axis response. Normally the tweeter will just raise the frequency of this off-axis depression. It's resolution and capability that is the main advantage IMO. Even a 6dB crossover that is phase coherent, is only coherent at the crossover frequency. The rest of the response between drivers is 90 degrees out of phase.
neo
Duke
« Reply #6 on: 2 Aug 2011, 06:56 pm »
Let me quote from page 419 of Floyd Toole's "Sound Reproduction: The Acoustics and Psychoacoutics of Loudspeakers and Rooms":
"Many investigators over many years have attempted to determine whether phase shift mattered to sound quality.  In every case, it has been shown that, if it is audible, it is a subtle effect, most easily heard through headphones or in an anechoic chamber, using carefully chosen or contrived signals... When it has been audible as a difference, when it is switched in and out, it is not clear that listeners had a preference."
The ear does not hear waveforms as such; rather, it deconstructs the incoming sound into energy at different frequencies.  So waveform fidelity is not nearly as important as eyeballing what happens to a square wave would lead one to believe.
On the other hand frequency response (not only of the first-arrival sound but also of the reflections) is a very reliable predictor of perceived sound quality.
Duke
« Reply #7 on: 2 Aug 2011, 07:50 pm »
Well, in practice we often get poor off-axis response with a two-way system (though it depends on the designer's priorities).  Let me give an example of what I'm talking about.
Here are the Stereophile measurements of a two-way that has an impressively smooth (though somewhat smiley-faced) on-axis response:
http://www.stereophile.com/content/focal-electra-1007-be-loudspeaker-measurements
In particular, look at the lateral off-axis response.  See that big energy ridge at 4 kHz?  That indicates the frequency response of the reflected energy, and it will strongly influence perceived tonal balance in most listening situations.  This anomaly is a result of the radiation pattern discontinuity between midwoofer and tweeter. [I am aware that Stereophile normalizes their off-axis curves, but in this case the on-axis curve is smooth enough that the off-axis data is still fairly easy to interpret correctly.]
On the other hand, take a look at this spec sheet of an 8" fullrange driver, in particular the off-axis response:
http://www.seas.no/images/stories/exotic/pdf_datasheet/x1-08_exotic-f8_datasheet.pdf
It has a few narrow-band jogs, but the overall trend is a gently downward-sloping off-axis response north of 2-3 kHz or so, with no major off-axis peaks like we saw in the first example.
In a situation where the perceived timbre is dominated by the off-axis energy (which I believe is usually the case), this fullrange driver has the advantage.
mark1965
« Reply #8 on: 2 Aug 2011, 10:01 pm »
"Midrange is king (at any age) and that is where single driver designs shine."
The above quote is why some people prefer single-driver/wide-band designs.
It really is as simple as that.
And for someone whose upper frequency hearing has greatly diminished and is looking for midrange magic, if well coupled with complimentary amplification, i.e., low-powered tubes, single-driver is a no-brainer, almost.
The trick is finding a really good one, which doesn't always entail the "lower price" part of the equation.
To the original poster apparently in Idaho, if you ever get to the Kalispell, MT area and want to hear some PHY-hp drivers in a true single-driver set up, look me up and you would be welcome to come by and hear my A23 SoloVox speakers.
Mark
neobop
  • BIRD LIVES
« Reply #9 on: 3 Aug 2011, 12:54 am »
Investigating phase nonlinearities in phono cartridges I came across an old paper by Ortofon. You can find this at Vinyl Engine. They tested some cartridges for phase anomalies. They found (with listening panels) dramatic differences in imaging capabilities. This was with the same cartridge with different amounts of damping, and with 5 other cartridges with varying degree of phase anomalies. There is a thread in the vinyl section on phase that has examples supporting the case for phase having much greater implications than generally believed by people like Floyd Toole.
http://www.audiocircle.com/index.php?topic=92138.0
There are other examples of a prominent hearing investigator saying that phase is more readily detected than small amplitude differences. In multi driver loudspeakers much of the phase differences between drivers can be overcome with driver placement (time alignment). Of course there are many other problems with crossovers and multi driver systems, like vertical dispersion. It was not my intent to present an argument for crossovers.
Duke,
Your previous post, while being non-representative of the situation, sums up the problem for me. The $830 Seas driver has 13dB difference between response at 400Hz and 17KHz. The plot for off-axis response is even uglier than on-axis. What price single driver? I know there are drivers with more reasonable on-axis freq resp, but with out the whizzer cone they probably have much worse off-axis performance. I think I'd go for the freq resp and aim the speakers at me.
neo
Duke
« Reply #10 on: 3 Aug 2011, 06:58 am »
The fullrange driver's off-axis response is a lot better than the two-way's, and my examples highlight the off-axis radiation pattern discontinuity that characterizes many two-way speakers.
The problem with "go for the frequency response and aim the speakers at me" is that, perceptually, the frequency response includes the off-axis energy.  Unless you listen nearfield or in a quasi-anechoic room, your ears cannot escape what's happening off-axis.  So that off-axis 4 kHz peak is still going to be audible.
On the other hand, listen off-axis of the fullrange driver and you can escape that rising on-axis beam because its relative contribution to the total off-axis energy is small, but probably beneficial.
« Reply #11 on: 3 Aug 2011, 11:47 am »
I use EnABL'd Fostex F200A in mass loaded transmission lines, and yes they beam:
http://www.fostexinternational.com/docs/speaker_components/pdf/f200a.pdf
But I listen nearfield (room/setup ala Cardas) and as you say, I can control the frequency response by aiming the speakers.  So this discussion seems to validate what I'm listening to, nice.  Thanks guys.
neobop
  • BIRD LIVES
« Reply #12 on: 3 Aug 2011, 12:34 pm »
In talking about listening on-axis and freq resp, I was referring to full range drivers. As a novice to full range speakers, I find the freq resp graphs of many to be a nightmare. I would also contend that the Focal speaker you selected is not necessarily representative of 2-way speakers. Whatever, the Seas full range response looks horrible on or off axis. What's the point of using a full range if the response needs correction? Without active EQ they need passive filters or a zobel.
It seems to me that losing the crossover is indeed the benefit of using a full range. The problem is finding a driver capable of doing it all. Some speaker systems talked about in this circle are not really full range systems. I have a set of speakers that have a woofer with flat response to 4KHz. I can run the woofer w/o any passive filter and use a high pass on the tweeters. I still consider them 2-way speakers even though they would qualify as full range.
It seems to me that something like this might be a more viable candidate. Notice the off axis response starts to diverge around 2K, like I said initially.
http://www.madisoundspeakerstore.com/approx-8-fullrange/fostex-fe203en-s-special-8-full-range/
neo
JohnR
« Reply #13 on: 3 Aug 2011, 03:21 pm »
Duke - brilliant! I had never thought of that before. Very interesting... I will have to look at some things in the (not too distant, hopefully) future with this in mind.
chrisby
« Reply #14 on: 3 Aug 2011, 05:25 pm »
neo
I've had occasion to hear a couple of models of Fostex's "special" series, and they can certainly sound dynamic and musical, although few would argue they're without some degree of "personality" (i.e. coloration).  Further, keep the following from Madisound's website in mind:
This artisan driver is a onetime production and Madisound has been allocated 25 pair for the US market.  The FE203En-S posses remarkably high sensitivity and is optimized for use in a folded horn enclosure. It is engineered to deliver effortless sound reproduction with a very dynamic character, and do so even with very low input amplitude. The result is a driver that performs exceptionally well from low to high listening levels.
Limit one pair per customer. This driver is a value at $600/pair.
Duke
« Reply #15 on: 3 Aug 2011, 05:58 pm »
Yes, but the on-axis response is only a small piece of the puzzle, and because fullrange drivers are inevitably beaming a lot more than a 1" dome would, their nasty graphs are only applicable within a narrow angle.  Move off-axis a bit and that on-axis curve is no longer representative of anything that reaches your ears, being now blended in with the off-axis energy, and making only a small contribution thereto.
The Focals use a stiff woofer cone that behaves closer to a rigid piston than most (which includes beaming more severely), and they also have a fairly flat on-axis response, and so illustrate my point well.  Many designers introduce an on-axis dip at the lower end of the tweeter's range to offset the off-axis pattern flare; that is a design choice I would have made.
If you have offsetting peaks and dips in the off-axis energy, the net result sounds a lot better than if you have a big energy ridge.  Dips that are not offset are fairly benign.  That upper-frequency "hash" doesn't sound nearly has bad as it looks to the eye; the ear tends to "average out" peaks and dips that are within 1/3 octave of one another.
Correction circuitry may offend the purist, but if it's a net improvement, I see nothing wrong wtih using it.  My first commercial speaker was an augmented Fostex fullrange driver (augmented by a built-in sub and rear-firing supertweet), and I believe the correction circuitry I used made a significant improvement.
« Last Edit: 3 Aug 2011, 11:02 pm by Duke »
neobop
  • BIRD LIVES
« Reply #16 on: 4 Aug 2011, 10:48 am »
Chrisby,
I was not recommending this driver, just using it as an example of one with more reasonable frequency response.
neo
neobop
  • BIRD LIVES
« Reply #17 on: 4 Aug 2011, 11:59 am »
Move back on-axis and ....
Yes, the Focals illustrate your point, but does it necessarily follow that this is an advantage for all examples?  The Focals are bright on or off-axis in the 3 to 7KHz region.  The Focal woofer has little to do with it. The crossover is at 2K, I don't know the slope. It would seem like the beryllium tweeter is the offending driver. With a crossover at 2K, I think there would be very little, if any woofer output at 4K. This is a hand picked example to illustrate your point, but is it typical?
Many peaks and dips are not offsetting. They tend to coincide. Once again you compare to that "big energy ridge". Is this typical?
Some kind of notch filter or cap/coil to roll off response? Do you think this was an improvement over a well designed multi driver speaker? This sounds like a 2-way with a rear firing tweeter.
I'm playing devil's advocate here because I think your argument uses a hand picked example that is not necessarily representative. It in no way reflects my opinion about your speakers. I don't even know what they are. You make some good points about off-axis response, but I think it would be better if you laid off those Focals. I question the relevance of this comparison.
neo
Richard in Idaho
« Reply #18 on: 4 Aug 2011, 07:01 pm »
This is all very interesting. Not sure on-axis / off-axis is of much importance to the way I listen to music.  I seldom set down just to listen. I like to have music in the background while doing other things. Still the music must sound good, be easy to listen to and not be tiring.
At this point I am thinking off the Tekton Lore. Just over $1,000 shipped plus any wood veneer over paint.
Duke
« Reply #19 on: 5 Aug 2011, 06:17 am »
If you listen from a wide range of locations, a fairly uniform radiation pattern is an advantage because that way the tonal balance will vary less from one location to another.
