Bryston Loudspeakers
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #860 on: 30 Dec 2012, 06:57 pm »
Hi James,
Which Bryston amp would you recommend, as a minimum, to drive the Bryston Mini-T speakers?
A lot would depend on room size and the levels you listen at etc.  They are 89dB so I would say a 3B or 4B would be a good choice.
James
Fido2
« Reply #861 on: 2 Jan 2013, 01:01 pm »
Quick question on the active version of the Model T's. I am thinking ahead and if I like what I hear I may opt on the active Model T's. Is the active crossover before the amps or after? Will I have to have 6 seperate channel of amplification and if so could I use say 2 14B SST's to drive the 4 channels of bass and mids and then get maybe a 4B SSTS for the tweets? This would be a mix of horizontal and vertical biamping...but would it work? In other words I would have a 14B SST on each speaker vertically biamped one channel going to bass one to mids. Then one 4B SST2 horizontally amping the tweets only...what say James?
« Reply #862 on: 2 Jan 2013, 01:37 pm »
Hi
Yes you need 6 channels of amplification and they all have to have the same "GAIN" - so any combination of Bryston amplifiers will work.
The Active crossover goes between the Preamp and the Amplifiers
Remember you have to have the 'Signature' series version of the Model T speakers if you want to later upgrade to the Active version.
http://bryston.com/products/speakers/Model_T_Signature.html
james
klao
« Reply #863 on: 4 Jan 2013, 02:48 am »
Any development progress on the subwoofer design, James?
Thanks.
gordon
« Reply #864 on: 4 Jan 2013, 05:09 am »
James
Would the new B135 handle the Mini-T's?
« Reply #865 on: 4 Jan 2013, 11:28 am »
Thanks.
Hi
Yes we are just finishing up on it now - boy the subwoofer market and the specification numbers they throw at you are arbitrary to say the least :duh:
James
« Reply #866 on: 4 Jan 2013, 11:29 am »
Hi Gordon
Yes it is really an excellent combo  :thumb:
James
HsvHeelFan
« Reply #867 on: 4 Jan 2013, 02:09 pm »
James,
Would a late 4B-ST do a good job of driving the model T's, with the 4B-ST driving the Model T's in stereo mode?
HsvHeelFan
« Reply #868 on: 4 Jan 2013, 03:09 pm »
James,
HsvHeelFan
Sure - 150 watts or so in most rooms will work just fine so anything beyond that is a bonus.
james
Alpha10
« Reply #869 on: 4 Jan 2013, 06:20 pm »
Hi James, we were just discussing on this side of the Pond, we have assumed that PMC will not bring your speakers into the UK, does that mean we will never see them, or can there be another route?
Cheers
« Reply #870 on: 4 Jan 2013, 07:47 pm »
Cheers
It's a good question an something I will have to discuss with PMC. It would be nice if we could work something out  :thumb:
Open for suggestions  :scratch:
James
Alpha10
« Reply #871 on: 4 Jan 2013, 07:57 pm »
James
It would be nice to think PMC would, making distribution easy for you. However, given what they have done to us with the recent BIT pricing I am not sure they would give you a fair fight for sales. The obvious thing to do would choose one or a few specialist retailers who could be your conduit.
Cheers
« Reply #872 on: 4 Jan 2013, 08:07 pm »
Cheers
Yes I was thinking with recent introduction of the Specialty Bryston dealer in the UK maybe only those few select dealers handle the speakers if they want?
James
« Reply #873 on: 4 Jan 2013, 08:21 pm »
Hi Folks,
The official mini t's production version have landed in my soundroom 1 - doing some listening tonight  :thumb:
james
won ton on
« Reply #874 on: 4 Jan 2013, 08:47 pm »
Hey James pass the remote,hmm which one.........LOL.
srb
« Reply #875 on: 4 Jan 2013, 08:49 pm »
Hi Folks,
As tall as those stands appear to be and the resulting height of the tweeter and midrange, do you watch movies standing up, or am I seeing just a distorted perspective in the photos?  ;)
« Reply #876 on: 4 Jan 2013, 09:04 pm »
Hi Steve
No I use the tall stands as a test to see how well the power response is into the room - seated or standing there should be very little change in tonal balance if all is right with the world. :thumb:
james
Alpha10
« Reply #877 on: 4 Jan 2013, 09:05 pm »
James
Sounds like a very good idea, yes please.
Cheers
Samurai7595
« Reply #878 on: 5 Jan 2013, 07:57 pm »
Good Day James,
Any idea what the Canadian retail price will be for a pair of stands (black) for the new Mini-T speakers?
« Reply #879 on: 5 Jan 2013, 08:21 pm »
Good Day James,
Hoping $399 list per pair.
James
