Bryston Loudspeakers
0 Members and 8 Guests are viewing this topic. Read 1438950 times.
bobNL
  • Some say he's a purist
Re: Bryston Loudspeakers
« Reply #700 on: 28 Oct 2012, 07:43 pm »
True!
When there is live music playing at a house nearby you instantly know its not reproduced but produced.
Would be the biggest complement for a sound system if it sounds like live music from a distance.
Bob
brucek
« Reply #701 on: 28 Oct 2012, 08:27 pm »
True!
Bob
Yeah, you can be walking down a busy city street, with cars and city workers and people making noise, but when you hear someone playing a piano or a saxaphone in a second story window apartment above you, it's instantly recognizable as being live. Why is that? How are we able to distinguish between that live piano and a stereo system playback?
brucek
Alphonse
« Reply #702 on: 28 Oct 2012, 10:16 pm »
James, I am curious about the Mini T. Is it a sealed box or ported design? If ported is it designed for flat frequency response or is there +-db bump in the 60-80 hz region to accentuate mid bass?
Thanks, Al
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #703 on: 28 Oct 2012, 10:23 pm »
Thanks, Al
Hi Al,
Ported at the rear top but flat frequency response - one of the advantages of a true 3- way.
james
mrhyfy
« Reply #704 on: 29 Oct 2012, 12:08 am »
James,,question about the dsp crossover version,,would you consider making a dsp crossover with a digital input and integrated volume control??   With all do respect..would there some theoritical loss of performance from the Dac 2 into the dsp crossover?  Also you're adding another step of transcoding even though done very well!
« Reply #705 on: 29 Oct 2012, 12:19 am »
Yes we have thought about a dedicated preamp crossover in a single box but is probably a ways out.
James
« Reply #706 on: 5 Nov 2012, 03:48 pm »
Pic of Bryston mini t loudspeaker.
james
« Reply #707 on: 9 Nov 2012, 01:32 pm »
Hi Folks,
Based on dealer and distributor feedback we are developing a smaller Center channel - Mini T Center
james
« Last Edit: 9 Nov 2012, 08:17 pm by James Tanner »
gdbalp
« Reply #708 on: 10 Nov 2012, 06:08 am »
Hey James,
Great, this was one complaint I had about the centre speaker.  Do you have the new dimensions of this speaker?
I believe the surrounds are 24" in length and wonder if there is a chance to reduce size to 18"?  Also, can these speakers be oriented on their longest side on a shelf?
On the subwoofer, has there been any developments - active or passive unit? If passive, what kind of amplification would be required - 5b st enough?
Just a general question about impedance of speakers(4 or 8 ohms), can you use both types in a surround configuration without concerns of timber or impedance matching issues?
Ciao, Luigi
« Reply #709 on: 10 Nov 2012, 12:04 pm »
Hey James,
Ciao, Luigi
Hi
Will measure the sample pair.
By surrounds are you meaning the Onwalls and Inwalls -  if so I have changed my mind and have decided to develop a new small 3way as the smaller 2way was not capable of the sound pressure levels and matching with the larger Model T's.
On the Subs there will be a passive version and depending on room size I would say between 300 and 600 watts.
The impedances will be nominally 4-6 ohms depending on the speaker.
James
gdbalp
« Reply #710 on: 10 Nov 2012, 05:08 pm »
Hi James,
I was referring to the Bryston mini t speaker, which I believe measure approximately 24" inches in length(height).  What I was asking is if dealers are asking for something smaller in length(height), 18" inches would be great and keep the same performance of this 3 way speaker.
On the passive sub question, 300-600 watts of power is from one or more channels of amplification?
Ciao, Luigi
« Reply #711 on: 10 Nov 2012, 10:29 pm »
Hi James,
Ciao, Luigi
Hi
No the Mini T can not get much smaller if I want the frequency response and power handling to be better than your average 2-way.
One channel of amplification per sub.
james
« Last Edit: 11 Nov 2012, 09:27 pm by James Tanner »
gdbalp
« Reply #712 on: 12 Nov 2012, 12:01 am »
Hi James,
Now I got it too....
Just wondering as you have reduced the size of the centre speaker by mounting the tweeter and midrange above each other.  Could this work for the Mini T speaker as well? This would standardize the speakers and possibility reduce manufacturing costs as well... As you can tell I have space constraints with my present shelves that hold my surround speakers, so it height is reduced than Mini T speaker is an option in future...  :thumb:
Ciao, Luigi
« Reply #713 on: 12 Nov 2012, 12:57 am »
Hi James,
Ciao, Luigi
The smaller Center will in fact be bigger the the Mini t and designed to go with the Model T.  A Center channel for the mini t would have to be about the same size with 1 woofer mid and tweeter
James
« Reply #714 on: 12 Nov 2012, 04:11 pm »
Model T Home Theater package with smaller Mini Center
james
PRELUDE
« Reply #715 on: 16 Nov 2012, 07:14 pm »
Hi James,
Have you ever thought to add the model T active to this list?
I think it would be a great competitor to the rest as price/value active package.
I see that Linkwitz just added his new LX521 to the list.So I assume you could do it.
http://thewelltemperedcomputer.com/HW/ActiveSpeakers.htm
« Reply #716 on: 16 Nov 2012, 07:53 pm »
Hi James,
Hi Prelude,
Will do but I have been so backed up getting the Passive and Signature speakers out the door I have just not had time to work on the Active crossover.
james
« Reply #717 on: 25 Nov 2012, 04:00 pm »
Hi Folks
We have about 20 pairs of Model T passive speakers out there now so should be able to provide some feedback for you soon.
James
« Reply #718 on: 25 Nov 2012, 04:53 pm »
Inner Ear Magazine
Nov 2012
Bryston shipped the Model T speaker over to my house and I am driving it (them) right now. It's actually one large pair of loudspeaker weighing in at about 100 pounds each.
I have had recent discussions of specs and their correlation to the listening experience— specs vs listening.
This is one of the rare occasions where measurements actually show precision and this was confirmed with my preliminary listening tests with the Bryston Model T speakers.
So far, I am delighted with this exceptional design . . . more to come very soon . .
Ernie Fisher
« Reply #719 on: 25 Nov 2012, 05:44 pm »
