Bryston Loudspeakers
0 Members and 23 Guests are viewing this topic. Read 1455894 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #2660 on: 26 May 2018, 01:35 pm »
Hi James,
I was wondering what would be the best way to add a Mini T Subwoofer to my Mini T speakers. The preamp I use has only 1 stereo output (going to the amp and them to the Mini T speakers). I see the Mini T Subwoofer only has a "mono" input. Is there a reason why you didn't make it stereo so we can use its internal crossover before sending the signal to the mains amplifier?
Also, would it be ok to place the Mini T speakers on a pair of Mini T Subwoofer (in a 2.2 system)? The height would be perferct and it would make it look like a floorstanding speakers without taking to much space in the room.
Hi Jay
The electronic crossovers in most subs are not of the quality we thought necessary to allow the Main signal to pass through or be manipulated.
So I have used the Mini T Subs with the Mint T's in Room 2 with excellent results just letting the Mini T's run full range and bring the Mini T Subs in using their rear panel controls to allow for a smooth transition.
I have not used the Mini T on top of the Mini T Sub but thats a neat idea but make sure you use some isolation and vibration control between the two.
james
« Reply #2661 on: 8 Jun 2018, 06:18 pm »
Mike-48
« Reply #2663 on: 13 Jul 2018, 09:52 pm »
James, thanks for posting the link to "What Are Measurements Good For?"  An excellent essay, IMO.
scirica
« Reply #2664 on: 30 Jul 2018, 11:34 pm »
James: How do I find out which generation tweeters are in my Model T’s? Serial numbers are 44167111510101SR Right and 44167111510001SR Left.
« Reply #2665 on: 31 Jul 2018, 01:01 pm »
Hi Steve
If they have a 'mesh' around the tweeter dome then they are the new tweeters.
james
scirica
« Reply #2666 on: 31 Jul 2018, 11:30 pm »
They do. Thanks James!
TJ-Sully
« Reply #2667 on: 31 Aug 2018, 01:39 am »
Hi James,
I used to own a pair of Mini T's and loved them. I traded them in for another brand (ATC) in an attempt to gain more midrange depth...if that makes any sense. Anyway, i've been missing the Mini's lately.
I am intrigued by the Model A's.
How would you compare the Mini T's to the Model A's in terms of soundstage, bass response, and SPL?
And...do they come in white?
Thanks as always,
TJ
« Reply #2668 on: 31 Aug 2018, 05:34 am »
Hi James,
Thanks as always,
TJ
Hi TJ
The Model A1's and A2's will play with greater SPL with less distortion than the Mini T's due to the double mids and tweets. Doubling up on drivers makes a huge difference when it comes to the ability to create real world dynamics.
Bass response will be similar with the A1's having a bit more low end capability than the Mini T's.
Sound stage is excellent on the A's due to the very small baffle so it might give the edge to the A Series when it comes to out of the box soundstage capability.
james
« Last Edit: 1 Sep 2018, 01:26 am by James Tanner »
« Reply #2669 on: 31 Aug 2018, 09:00 pm »
SUBJECT: Bryston Mini A Speaker – Dealer Comments
September, 2018
Bryston Mini As are back in stock and in a new(ish) finish - Espresso Walnut. I have to say this loudspeaker is one of the best values in our store.
It seems like a good time to quote myself from way back in November of 2015.
"Every once in a while a product comes along that completely defies expectation. The Bryston Mini A is that product! ...
This modestly sized, three-way stand mount loudspeaker is remarkable in its ability to disappear.
The bass weight is fantastic considering the low end duties are left to a 6 1/2″ woofer. Coherence is another strong suit; close your eyes and you’d swear you were in front of a pair of Magnepans.
They are that good.
At $1500.00/pair, they may be over looked by some and that would be a big mistake."
Simon,
Audio Ark
TJ-Sully
« Reply #2670 on: 1 Sep 2018, 12:07 am »
Thanks James!
TJ-Sully
« Reply #2671 on: 18 Sep 2018, 12:22 am »
Hi TJ
james
Hi James
I just purchased a pair of Bryston Model A1's - and after only 2 listening sessions - all I can say is WOW! These babies are the real deal.  Effortless power.  Will write more once they get settled into my room and i finish tweaking placement, etc... but super happy so far!
back to an all-bryston system once again - from source to speakers!! Love it :)
TJ
« Reply #2672 on: 18 Sep 2018, 10:52 am »
Hi James
TJ
Hi TJ
Great to hear your comments about the Bryston A1 speakers - I know it sounds ridiculous and self-serving but at this price point I truly believe our Bryston speakers rival speakers costing 2 to 3 times more.  The negative comments I get on our speakers always has to do with the more traditional cosmetics (they are not pretty enough) - but that is not what our speakers are about - they provide state of the art performance and represent incredible value. :thumb:
james
Mag
« Reply #2673 on: 18 Sep 2018, 11:35 am »
Exactly, I can't see my Model T's, cause they're black and I'm sitting in the dark about to crank some music. It's performance not cosmetics for me. Audiophiles would be amazed at the soundstage imaging I get from these speakers in my 8'x 11'x 25' room. :drool:
TJ-Sully
« Reply #2674 on: 18 Sep 2018, 08:46 pm »
Hey Mag - I've got the black versions too - and very impressed with the quality of the finish - nice and smooth with evident wood grain.
Totally agree with JT and your comment - it's all about high performance and value for the money. AND the incredible 20-year warranty from a Canadian company is icing on the cake. Not to mention their stunning ability to maintain control at higher volumes.  Just FANTASTIC!  :thumb:
Thanks Bryston!
TJ
ps. try listening to "Burn One Down" from Ben Harper's Live from Mars album. The percussion / drums are so freeking real it's unbelievable. Give 'er a go!
Mag
« Reply #2675 on: 19 Sep 2018, 01:28 am »
Don't have that one, I've been listening to Sade (smooth jazz) lately on Youtube. I find her music to be audiophile quality and really shows off my $40,000 Bryston stereo system. :inlove:
TJ-Sully
« Reply #2676 on: 19 Sep 2018, 10:03 pm »
Mag - not sure if part of your Bryston system includes a Digital Player and DAC - but if it does - I'd recommend getting setup with Tidal/Roon. You'll have access to essentially unlimited musical selections - and at CD resolution (minimum). I believe to be very good value for the money.  :thumb:
Mag
« Reply #2677 on: 19 Sep 2018, 11:10 pm »
Thank you for the suggestion but streaming is not for me. I watch Youtube to find an artist I like, just placed an order for 9 blu ray titles.
For me it's the BCD-3 although I have the BDP-1. I docter music through a mixer, then I play the cd-r with the BCD-3. The result is digital music in another league, better than anything else I've heard including blu ray by a small margin.
The BCD-3 IMO is the best digital source on the market.  :smoke:
gene9p
« Reply #2678 on: 19 Sep 2018, 11:39 pm »
you tube on a 40,000 dollar system... :duh: :duh: :duh: :duh:
Mag
« Reply #2679 on: 20 Sep 2018, 12:10 am »
Do you not know how to read?
