Bryston Loudspeakers
0 Members and 16 Guests are viewing this topic. Read 1436044 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #2140 on: 17 Jun 2015, 09:04 pm »
Hi Gene
Are you stands OK with the larger Mini T's?
james
gene9p
« Reply #2141 on: 17 Jun 2015, 09:53 pm »
I plan to try that tomorrow..maybe tonight.......The B&W stands can hold up to 50lbs and I have to check the plate size.  I have plenty of Blu Tac. Right now I have them 6 inches off the floor on some hard wooden storage cases.  I did have to block the rear ports with foam to control the bass in my set up. They only had 30 minutes of play time on them according to the seller, so break in is needed.
« Reply #2142 on: 17 Jun 2015, 10:14 pm »
Yes they go very deep so you should not need the Sub
james
gene9p
« Reply #2143 on: 17 Jun 2015, 11:37 pm »
Sub is off.....still prefer them with ports blocked presently.I had blocked the ports on the Mini A's for a while also. I placed one on the 24 inch stands and I think it is too high. They sound pretty darn good only 6 inches high but I do want to get them up a little higher. Perhaps a 16 inch stand would work for me. I'll be doing my homework while running the Mini T's. It's a work in progress. It took a while for the Harbeths to settle in and quite a bit of fine tuning location b4 I finally got it just right. My room acoustics aren't the best for sure.  :icon_lol:
« Reply #2144 on: 17 Jun 2015, 11:42 pm »
Don't be too concerned on the height as they have very wide dispersion so there is a lot of leeway in height placement.
james
gene9p
« Reply #2145 on: 18 Jun 2015, 12:49 pm »
I am thinking about these in silver or black..VTI 19 inch stands
http://www.standsandmounts.com/vtiufseries19inchspeakerstandsblackorsilveruf19.aspx
« Reply #2146 on: 18 Jun 2015, 12:57 pm »
Looks good Gene - I assume you can fill the tubes?
james
gene9p
« Reply #2147 on: 18 Jun 2015, 01:45 pm »
YES..I am also looking at the Target - FS-Series Speaker Stands, 20 inch height but cannot find any info on how much weight they can hold.
« Reply #2148 on: 18 Jun 2015, 02:46 pm »
Hi
The FS are good up to 70 lbs.
james
gene9p
« Reply #2149 on: 18 Jun 2015, 03:34 pm »
great..I am going to order them from Music Direct.com  :beer:
So far the Mini T's are pretty incredible..a favorite new Cd of Bob James's live concert that he autographed for me recently sounds great, very detailed and full rich sound. One would think he was playing the piano right here in my apt.
« Reply #2150 on: 18 Jun 2015, 04:06 pm »
Hi gene
Glad you are enjoying the speakers - I think as you move along they will surprise you with their ability to sound musical and full range but still resolve very low level micro details. :thumb:
james
scirica
« Reply #2151 on: 18 Jun 2015, 04:08 pm »
Hey James:
I got an update this week that my Model T's and Mini-T Center should be on their way to my dealer soon. I can't wait them to make the long trip from Canada to the dealer and then on to Texas.  Please package with care!!!
« Reply #2152 on: 18 Jun 2015, 04:16 pm »
Hey James:
Hi
Yes we got the veneer in on Wednesday so they are currently in production.
They have to go on a skid as they are too heavy for Puralator or UPS etc.
james
scirica
« Reply #2153 on: 18 Jun 2015, 04:31 pm »
Hi
james
Take your time...I want perfection  :green:
Feel free to add in a prototype BDA-3 while you're at it  :lol:
gene9p
« Reply #2154 on: 18 Jun 2015, 10:10 pm »
My new stands..perfect fit..20 inches high ....love the color...LOL :D
.....the target stands should be here Saturday...
Grit
  • - Garrett
« Reply #2155 on: 19 Jun 2015, 07:42 am »
Hahaha! I love your innovation!
« Reply #2156 on: 19 Jun 2015, 01:40 pm »
Hi Folks,
My latest setup in RM 2 - Mini T speakers with Mini T Subs.
james
gene9p
« Reply #2157 on: 19 Jun 2015, 02:24 pm »
Beautiful!!!
Love the Pioneer Elite Plasma..should never have sold my pro 111FD...the best tv ever.
Can you share some info about the stands for the Mini T's?
« Reply #2158 on: 19 Jun 2015, 03:05 pm »
Hi gene
I am going to change the stands to Target as the stands in the picture are too light in weight and a little tippy.
james
gene9p
« Reply #2159 on: 20 Jun 2015, 04:09 pm »
messing around while waiting for delivery..here they are temporarily on the 24 inch B&W stands.
I found turning the top plate the long way and removing the bottom rubber feet from the speaker makes a better fit..the rubber feet or spikes can
 be added after placing the speaker on stand..seems hard to do if they are still on b4 placement.
