Bryston Loudspeakers
95Dyna
Re: Bryston Loudspeakers
« Reply #1760 on: 25 Aug 2014, 04:17 pm »
Hi,
First time I have seen this - it is definitely aftermarket - where did you get the picture from?
james
James,
This pic is from the What Hi Fi review on their website.  I don't know where they got the pic. The platform seems like a good idea to tidy things up behind the Signature Passive, eh!
http://www.whathifi.com/forum/hi-fi/bryston-model-t-signature-speakers-demo
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1761 on: 25 Aug 2014, 06:12 pm »
James,
Yes that was a review they did in Malaysia at James Tans demo room.
james
ellsworth
« Reply #1762 on: 26 Aug 2014, 01:35 pm »
In my opinion, these stands look a little too large for the cross-overs. What I'd like to see is a smaller set of outriggers with spiked feet that match the ones under the speakers. James, any thoughts on this? Thanks.
« Reply #1763 on: 26 Aug 2014, 02:18 pm »
Not a bad idea - I will look into that.
james
Scar
Re: Bryston Middle T or Axiom LFR1100
« Reply #1764 on: 26 Aug 2014, 11:53 pm »
Greetings and salutations! I would appreciate any feed back you have in regards to these two speakers. I realize it is a bit of an apple oranges comparison with the Axiom's being an omni type speaker.  I am using in an 12' by 18' room that opens up to a 12' by 10' kitchen. I would use a Moon 340i or similar for the Bryston's. For Axiom I would use their amp with Copland CTA 305 pre.
Love the T's Haven't heard any Axiom's. Able to get the Axioms used for $2200. Bryston would be over double.
Seeing how many major high end manufacturer's do not offer a dipole/omni type speaker leads me to wonder if it is really that good of a speaker design.
Any information is greatly appreciated!
« Reply #1765 on: 27 Aug 2014, 11:42 am »
Hi Scar
Well sir you have asked a very important question and one that has been rampant for decades.  The concept of a 'radiating sphere' where the polar response of the speaker is flat and even in every direction has long been the goal of many speaker manufacturers. One driver handling the full frequency response and able to radiate its energy in a perfect circle (sphere) both horizontally and vertically has been the lofty goal of many.
So the different speaker designs to some degree attempt to approach this goal in a variety of ways. Omni speakers (drivers front and rear typically) are the closest to this goal in theory but getting the right balance (Power Response) into real rooms has been a challenge and optimizing driver arrays to have equal radiation in every direction is very difficult to achieve.  So Dipoles, Bipoles, omnis, direct radiators etc. are all attempts to optimize the power response and frequency balance in typical rooms with typical dimensions.
The new Axioms are probably the closest at doing this now for a number of reasons.  One of the issues that has arisen is that if the rear wave is equal in volume level to the front wave it tends to make the speaker sound too bright in most environments.  It is one of the issues bipoles and dipoles have to address and in many of these designs the rear wave is attenuated a bit to account for this in the internal passive crossover.  In the new Axiom they control this rear wave set of drivers using specific electronics rather than passive components in the loudspeaker.  So the radiation pattern is adjusted at the preamp level and forwarded to the power amps (you need 4 channels with the Axiom). The advantage of this approach is you can now easily control the rear radiation pattern electronically independent of the front radiation pattern whereas in a passive system this is not possible with the same precision.
With a direct radiator like the Model T it is a more conventional approach and the radiation pattern is more forward into the room as there are no drivers on the rear of the speaker. We believe though that the radiation pattern even in the forward direction should be as wide and even as possible in both the vertical and horizontal planes.  The Power Response on the Model T is as accurate as can be accomplished in today’s designs and I am very proud of what we have achieved with all the Bryston speakers in this regard.
So with that background choosing the right speaker for you’re application is definitely something to consider.  The complexity of the setup, the rear wall symmetry, the electronic necessities, number of amplifier channels, type of soundstage required etc. all enter into the equation.
Hope this helps.
James
« Reply #1766 on: 28 Aug 2014, 05:29 pm »
Hi James,
We're eagerly awaiting our demo Middle T.  Looks like they will arrive in the next few days.
The Model T are an incredible value, we have them anchored by the mighty 28Bs in our 26 x 13 listening room.  These svelte beauties are jaw dropping…they fill the room with deep, tuneful bass.  Mids are transparent and beautifully detailed and the top end is composed and crystal clear.
The fun continues...
Sincerely,
Robert
servingko
« Reply #1767 on: 28 Aug 2014, 06:39 pm »
I have been enjoying my Middle T's for almost three weeks now and all I can say is "amazing"!  It's very easy to look at a speaker and think, "what's the big deal?  A box and some drivers - how different can they be from similar designs."
It's this thinking that has spawned countless would be speaker companies and thousands of DYI projects that aren't quite there.  These are sooo "there" in all aspects and have me contemplating a complete five channel setup.
« Reply #1768 on: 29 Aug 2014, 01:06 pm »
This is a very interesting comment Servingko and something I learned when we were developing the speakers just how important the blind listening tests were between very similar measured speakers.
james
« Last Edit: 29 Aug 2014, 02:48 pm by James Tanner »
« Reply #1769 on: 4 Sep 2014, 04:36 pm »
SUBJECT: NEW BRYSTON SPEAKER DEALER
September  2014
We would like to welcome ‘Altronics Stereo 2000’ in Toronto’ as our latest Bryston Speaker Dealer.
« Reply #1770 on: 4 Sep 2014, 05:17 pm »
Hi Folks,
‘SENNHEISER in AUSTRALIA’
as our latest
Bryston Speaker Distributor.
« Reply #1771 on: 7 Sep 2014, 02:08 pm »
Hi Folks,
In this months Sound and Vision Magazine they did a full review on a Bryston Surround system and we got a TOP PICK AWARD.
I will post the PDF link soon.
james
« Reply #1772 on: 8 Sep 2014, 12:13 pm »
SUBJECT: Bryston Speaker Distributor
September 2014
Hi Folks,
‘RICHCOLN IN HONG KONG’ as our latest Bryston Speaker Distributor.
« Reply #1773 on: 8 Sep 2014, 02:04 pm »
Hi Folks,
This coming from a very discriminating dealer - Dave's Faves -  :thumb:
http://www.audioemporium.com/daves-faves-bryston-model-t/
james
« Reply #1774 on: 15 Sep 2014, 04:00 pm »
September 2014
Hi Folks,
Bryston would like to welcome: ‘AV DESIGNS in MALASYIA’  as our latest Bryston Speaker Distributor.
mr_bill
« Reply #1775 on: 15 Sep 2014, 06:35 pm »
Hi Folks,
james
James, I may have asked this before but what is the finish of the T's in your Signature and also in this review?  They are very nice.
Is there an upcharge for custom veneer and are the veneer choices limited?
Bill
« Reply #1776 on: 15 Sep 2014, 07:04 pm »
Bill
Hi Bill
That is the Walnut veneer - no up-charge for Walnut over standard wood finishes (Boston Cherry, Natural Cherry, Black Ash)
james
« Reply #1777 on: 16 Sep 2014, 03:23 pm »
September 2014
Hi Folks,
I will have the PDF shortly for the latest review in Sound and Vision Magazine of a complete Bryston speaker Surround system.
Some of my favorite quotes:
•   With final placement of the Mini T’s settled, what I encountered was exceptionally neutral, uncolored reproduction ... with as complete an absence of discrete response anomalies as I’ve ever heard.
•   The bass the “compact” Mini T Brystons could hurl into the room was truly astonishing. Rich high-frequency content like brushed cymbals were virtually perfect.
•   Stereo listening whetted my appetite for multichannel. The result was outstanding! These Brystons are immensely transparent speakers. Nor were the Mini T and its mates impressive only on the big stuff. From the lowest C to the highest harmonics, were as convincing as I’ve ever heard from reproduced sound.
•   These are, in short, very, very well-executed loudspeakers and finished to Bryston’s long-established high standards, speakers that will fully reveal what is on a recording for better or for worse.
« Last Edit: 16 Sep 2014, 04:25 pm by James Tanner »
So There
  • Brystonized
« Reply #1778 on: 16 Sep 2014, 05:51 pm »
Well done, James. Congratulations on the excellent reception of Bryston speakers.
Rich
_______________
Shaky Napa Valley
« Reply #1779 on: 16 Sep 2014, 11:13 pm »
