Bryston Loudspeakers
0 Members and 16 Guests are viewing this topic. Read 1437951 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #1180 on: 1 May 2013, 07:33 pm »
Hi Folks
Based on yesterdays memo regarding how Bryston measures/designs our subwoofers (see previous page) some have asked why go to all the trouble of using a 90 foot Tower outdoors given other more typical methods available for measuring subwoofers.
We could bury the subwoofer in the ground and get a true 2-pi measurement or we could use the more widely utilized near-field technique.
However, we don’t because we ‘have the ability’ to make a true 4-pi measurement. It is the “purest” and most direct and correct way. It is also VERY CONSISTANT, something that cannot be said for ground plane or near-field methods, unless an identical environment is used and the subwoofer position is not changed.
We also need this 4-pi ability to make the appropriate low frequency correction curves for our anechoic chamber and this must be done for EACH subwoofer model.
Finally, near-field computer techniques are fine for response at low volume levels, but impossible when trying to characterize subwoofer performance at high levels. It’s simply a matter of microphone overload levels when measuring near-field.
We also use the tower to confirm the low frequency response of our larger speakers like the Model T and Middle T.
james
« Last Edit: 2 May 2013, 12:43 pm by James Tanner »
Habs Fan
« Reply #1181 on: 2 May 2013, 02:47 am »
I know the general  area where that tower is located.
Great deer stand with excellent sight  lines over looking the park.
How does one get a 100lbs worth of speaker up  there?
« Reply #1182 on: 2 May 2013, 09:57 am »
It has a motorized platform lift.
james
95Dyna
« Reply #1183 on: 2 May 2013, 01:23 pm »
Hi Folks,
Finally got my Center Channel Model T today - installed and ready to go  :thumb:
james
Hi James,
I see that room frequently in the various (2) channel setups you have displayed .  What are its dimensions?
« Reply #1184 on: 2 May 2013, 02:20 pm »
Hi
16.5 feet x 23 feet x 8 feet.
james
« Reply #1185 on: 3 May 2013, 10:48 am »
Hi Folks,
Starting to get some dealer feedback on the new Bryston “MIDDLE T” speaker we just introduced:
Sent: Thursday, May 02, 2013 5:15 PM
To: James Tanner
Subject: Re:
Hi James
The MIDDLE-T I think will be a big seller, they sound fantastic!
Mark Jones
Whitby Audio Video
« Last Edit: 3 May 2013, 12:48 pm by James Tanner »
« Reply #1186 on: 3 May 2013, 06:12 pm »
Hi Folks,
Still hard at work fine tuning the ACTIVE version of the Bryston Model T loudspeaker.
Here are two of the anechoic measurements with the Bryston AX-1 Active crossover and the Model T speaker.
Model T Listening Window:
Model T Listening Window and Sound Power:
james
« Reply #1187 on: 3 May 2013, 06:48 pm »
BRYSTON MIDDLE T DEALER FEEDBACK
Sent: May-03
To: Bryston: James Tanner
Subject: Middle T
Hi James,
I just received my Middle Ts.
I am extremely impressed with their performance!
They have huge bass and power handling- to go along with excellent clarity without being bright.
I think you've completed the HAT TRICK now with Model T, Mini T and Middle T.
Congrats and THANKS - for doing such a fine job with your speaker family!
Dave
Audio Emporium
« Reply #1188 on: 7 May 2013, 06:24 pm »
Hi Folks,
Been asked to post a pic of the rear of the Model T Signature/Active version:
« Reply #1189 on: 7 May 2013, 06:26 pm »
Also working on the Literature text for the Active Version of the Model T:
First draft:
BRYSTON MODEL T ACTIVE SPEAKER
The Bryston Model T loudspeaker is also available in a fully ACTIVE version.
Active loudspeakers differ from Passive speakers in that the crossover that determines which drivers (Tweeter, Midrange and Woofer) get which audio frequencies is controlled by an ELECTRONIC crossover placed between the preamp and the power amplifiers rather than the passive crossover version which is typically built into the loudspeaker. Also all the drivers in the loudspeaker (T.M.W.) have an independent amplifier channel controlling them as opposed to a Passive crossover where one amplifier channel controls all the drivers in the speaker. So an Active 3-way speaker like the Bryston Model T requires 3 separate amplifier channels per speaker whereas the Model T Passive only requires one amplifier channel per speaker.
The advantage of an electronic crossover placed between the preamplifier and the power amplifiers is all the speaker control (crossover slopes, crossover points, gain etc.) are performed at what is called low level signal levels whereas passive crossovers are operating at what is referred to as high level signal levels. Manipulating and adjusting signals at low levels is far more accurate than attempting the same with high level signals. So if you look at the frequency response, the crossover slopes and the volume levels per driver required the Active crossover provides much more accuracy than the passive option.
If you refer to the graph of the Bryston Model T Active loudspeaker on page (?) you will see two graphs – one is the ‘Listening Window’ and the other is the ‘Sound Power Response’. With an Active crossover we can adjust and design these two performance areas of the speaker separately and independently whereas with a passive crossover they have to be adjusted in tandem.  So in a passive system an adjustment on the listening window affects the sound power directly and vice-versa.  The importance of the listening window and power response in a loudspeaker is explained in detail on page (?). So the flexibility and accuracy that Active crossovers provide cannot be underestimated from a performance perspective.
The other advantage of Active loudspeaker systems is the fact that the amplifiers output stage is directly connected to the loudspeaker driver.  So the Woofer, Midrange and Tweeter all have separate amplifiers controlling their movement directly rather than having to deal with passive components (capacitors, inductors, resistors etc.) required by passive networks. If you recognize that music is essentially a transient condition, a ‘stopping and starting’ as the music signal requires then any system that can control this stopping and starting of the drivers is much more capable of an accurate rendition of the input signal.  The transient response improvement with the direct connection between the amplifier and speaker in the active system. is mainly due to the fact that the main filter components in a passive crossover network, the inductors and capacitors, are energy storage devices. By definition they both suffer from forms of hysteresis where there is a delay between the energy storage and the release of that energy. This leads to a distortion of the signal’s time signature and it will also be frequency dependant to some extent. The other big area of benefit is that fact that the passive filter network has intrinsic losses and these losses translate directly into a reduction in the amplifier power that actually makes it to the loudspeaker drivers. Removing those losses from the equation translates into a more efficient transfer of energy between the amplifier and the loudspeaker.
If you are considering moving to an Active system at some point in the future then purchasing the Bryston ‘Signature’ version of the Model T loudspeaker is a great first step. You would simply replace the external passive crossover that comes with the Signature version of the speaker with the Bryston AX-1 Active crossover and add 4 more channels of amplification.
« Reply #1190 on: 8 May 2013, 02:32 pm »
Hi Folks,
Please see that link below – it is the Bryston Model T loudspeaker UPDATED brochure – it now includes info on the ACTIVE version of the Model T as well as the dedicated AX-1 Electronic Crossover.
ftp://ftp.bryston.com/pub/brochures/2013_Bryston_Model_T_Brochure.pdf
James
« Reply #1191 on: 8 May 2013, 08:36 pm »
DEALER FEEDBACK Bryston Model T Speaker:
Friggen great....... love the model T
AP
« Reply #1192 on: 9 May 2013, 03:53 pm »
Hi  James
Believe it or not Model T speakers on a Bryston B100 integrated amp- incredible!!!!
« Last Edit: 9 May 2013, 04:54 pm by James Tanner »
« Reply #1193 on: 11 May 2013, 11:40 pm »
SUBJECT: Dealer Comment – Bryston Speakers
DATE:  May 2013
DEALER COMMENT – Smiths Custom Audio
Hi James
My god after teasing myself with the mini t and then having the crap kicked out of me by its BIG BROTHER Model T aka the ‘BIG T’…
I have finally given the Middle T a good listen and what a GREAT SPEAKER!
Can't say anything but WOW what a great speaker line up and the VALUE of all these speakers is absolutely superb...
Thanks James, and the whole Bryston Team you have made dreams come true once again.
Smith’s Custom Audio
Lethbridge, Alberta
P.S. -  Take one pair of Model T's and some Bryston Power one Music Player and turn up Michael Jackson's  "DIRTY DIANA" it has never sounded like this…. my pants were shaking …… AMAZING!
klao
« Reply #1194 on: 13 May 2013, 05:53 pm »
Hello James,
I noticed the Model T Sub MSRP is $4,195 each.  (Did you try them with the Maggie 20.7 yet, btw?)
How about the smaller Bryston sub's MSRP?  Also how did it performed/measured up on that 90-feet tower?
Klao
« Reply #1195 on: 13 May 2013, 06:01 pm »
Hello James,
Klao
Hi,
Yes they worked great with the MG20's - really blended well.
Still working on the smaller Sub but around $3000
Both subs really go deep and the power amp section is the same on both.
james
« Last Edit: 14 May 2013, 08:33 am by James Tanner »
« Reply #1196 on: 13 May 2013, 08:41 pm »
SUBJECT: Bryston Model T Signature Speakers – WOOD ONLY
Hi Folks:
IMPORTANT:
Please be advised that going forward the Bryston Model T ‘Signature’  Speakers will only be available in real WOOD finishes (no vinyl)
The ‘Passive’ version of the Model T will continue to be available in both Vinyl or Wood finishes.
We still have a few Vinyl Signature series units available so please let me know if you have any interest in these last few.
Bryston Ltd.
alexone
« Reply #1197 on: 15 May 2013, 04:01 pm »
James,
now that the Hi End show in Munich is over...are the Bryston speakers now available in Europe?
thanks,
al.
« Reply #1198 on: 15 May 2013, 04:23 pm »
James,
thanks,
al.
Hi Al,
We certainly had a lot of interest and Holland has come on board immediately.
james
« Reply #1199 on: 18 May 2013, 11:51 am »
New Bryston mini t speaker review on the way - excerpt:
“Over the weeks that I spent with the Mini T’s, I did not find a single track or musical category that did not sound absolutely right.
During this review, these speakers continued to sound better and better!
Nice beginning, Bryston.”
